Difference between THB6064AH and THB6064H
yumin
Easy way to use THB6064Ah replace THB6064H
1. Use a resistor(the value is between 24K and 180K,Recommend:51K) to replace the C17 capacitor of Pin23 ;
2. Use a any value resistor to instead of C16 capacitor of Pin3,or short it out directly;
3. Remove the R11 to make Pin 4 be High level or Low level.
According the above method, decay of THB6064AH will be 20% or 60% fast decay. If the noise and the vibration are not ideal in this condition, you can remove C16, then connect Pin3 with Vcc directly. At last, you should change the decay into other decay mode.
Refer to Differences between THB6064Ah and THB6064H,please see the attachment.
