Diagram of a 8051 Digital IO pin.
alphacat
Hello.
I have a 8051 Uc and I can configure the Digital I/O pins to be one of the several options below:
1. Input with an internal pull-up.
2. Input with an internal pull-down.
3. tri-state.
4. 1L output.
5. 0L output.
How does a diagram of such pin looks like?
Thank you.
What do you mean diagram? You just listed all the options so that's what your diagram would look like.
Hello.
3. tri-state.
4. 1L output.
5. 0L output.
Thank you.
Such a diagram is pretty common fare for a manufacturer's datasheet or hardware manual. Do you have one? Can you find one? Do you need me to hold your hand and give you a link?
BTW which 8051 variant can source current in the high state or be configured with a pull-down?
I was wondering the same thing myself, pull-downs aren't common.
Hey,
@Papabravo:
The spoken 8051 Uc is CC2430.
In its datasheet, there's no diagram for how its implement electrically.
(There's only diagram there of interrupts, but it doesnt mention there the pull-up/downs, input/output configuration).
@Sceadwian:
I know how its described verbally, but i dont know how its plotted.
Therefore i'd love to see such diagram.
For example, i know how to *program* the Uc's pin to be pull-up connected, or pull-down connected (in case its configured to be an input), but i dont know how its done electrically.
I see the problem now. The CC2430 has an 8051 core, but it does not have 8051 compatible I/O pins. You are correct in stating that there is no diagram.
One possible way to do pullups and pulldowns on the inputs it is:
On an input a pullup is implemented with a weak p-channel FET that has from 20K to 40K ohms of channel resistance. The gate of this p-channel FET is connected to a register bit which can be enabled by the program. The pulldown is implemented in a similar way with an n-channel FET having 20K to 40K of channel resistance.
Another key difference is that the pins have symmetrical output drive which is definitely NOT 8051 compatible.
