detecting pulse width using PIC
mr. mister
hello all
i'm trying to feed the output of one channel of a 6 channel receiver into a PIC, the channel is controlled by a switch i can flick on or off
i've been told that the pulse window for the output generated by the receiver is about 20ms, hence in this case i am assuming that since the channel is controlled by an on and off switch there will only be two types of pulse widths generated
what i want to know is how do i go about using the PIC to detect one pulse width as a high and the other as a low???
as i am still quite a novice with the PIC, i understand tht i have to use the timer aspect but i don't really understand the prescaler business. How do i measure the pulse width and assign one width to be recognised as a high and the other a low?
i couldn't quite find a clear explanationfrom your tutorials
the problem is that i somehow need to read the incoming pulses like i explained (should be two only since the channel is operated by a switch), thing is i don't know how to read from the timer, will this be;
MOVF TMR0, W
MOVFW count
is this correct? placing it in a file register named count?
if so, how then do i set this as the only input recognised as a high so that when the switch is flicked in the other direction it is recognised as a low and no action is taken?
thanks in advance
also i am aware that when the switch is flicked in the other direction, it will give a different TMR0 count due to a different pulse width
my main problem is using the program to detect one pulse width and setting it as the only recognised input
It's no where near as simple as that, you need to use a timer module in CCP mode, you need to study the datasheet for explanations of how that works.
But, as I mentioned previously, you can do it with a simply software loop - as my IR tutorial uses. You might also like to consult the inline book that gives a suggested replacement for the BASIC PulseIn command at .
