Designing a homemade electric lighter
I'm trying to make an electric lighter ( like this https://imgur.com/a/wg8q7) using the framework of this guide.
https://www.instructables.com/id/Make-a-battery-powered-soldering-iron/?ALLSTEPS
except mine will have a few more feature and the soldering tip will be replaced with nichrome most likely.
Theres is just a few things that I am stuck on
-First, Is nichrome the best material to use as the heating element?
Assuming we do use a wire heating element the length of the wire will be 1.5-2 inches long, what would be the best gauge? any other details about it?
-Second, I need the heating element to stay at a constant temp of at least 500 Fahrenheit
What type of circuitry would I need to accomplish this, what if i wanted to to be able to control the amount of power?
-Third, what would be the best batteries to use for this? I was hoping to be able to use 4xAAA or 3AA
1) nichrome would be my first choice, use ohms law
2) pwm (555 timer, pic)
3) yep
:(that is still on my to-do list
3) yep
thanks joe
Can you help me use figure out ohms law? Total noob here.
If i were to use 3AA batteries what would be the voltage and power supplied?
say, (1.3V per battery*3) / .5A
3.9V/.5Amps=7.8 ohms
Volts/Resistance=Amps
Volts/Amps=Resistance
