Denon AVR-589 protect mode
L Spaugh
Any suggestions on where to look to fix a Denon AVR-589 receiver from going into protect mode?
Normally it's one side of the amplifier that's blown - so you have a high DC voltage on the output, which is what the protection is for (to prevent the speaker been destroyed).
check for offset on the amp outputs. if you have rail voltage on the output isolating coils, you have a shorted pair of output transistors. another common protection problem with Denons is bad power supply regulators. in some models, the +/-15V regulators had a habit of going south. if you find one of them bad, replace both. those are the most common problems. lesser common problems are a bad active filter transistor for the diff amp supply (looks like it's used as a regulator, but it's really an "amplified capacitor" or capacitance multiplier). this would cause 20-25V offset in all amp channels at the same time. or a bad main power transformer (the main clue on this one is no display when the unit turns on).
i wouldn't get too far into a 589, or any other 3-digit model, as they're the "low-end" Denon receivers. if it's not just a pair of outputs and the resistors around them that's bad for instance, then it's not really worth spending lots of time and money fixing.
