DELL Monitor E173FPs flashing green light/Blank Screen
EasternTIGERS
Hi everyone, today I got a DELL Monitor E173FPs, It is a 17" flat screen LCD, The problem is it turns on and flickers, the green button light flashes and the screen is blank with flashing, I also hear a very low noise clicking sound towards the left of the screen when pluged in and the monitor is on, even when I press the off switch or even hold it nothing happens. I opened it and the capatator looks fine, what is the problem? This link is my exact board this Monitor uses.
everyone
wow, not one reply, oh well. I guess that sums it up.
Have you assured yourself that it's is indeed receiving a VGA signal from the PC? Assure that your PC is set to properly operate the Dell panel with its VGA signal.
Hi buddy thanks for the reply, problem solved, I used a Dell PSU and it worked, problem was their systems only use their own components you cannot use other makes on dell machines
That goes as well for their notebook power adapter...generic won't recharge battery.
