Delay Symbol Question
Just a quick question. What does the $ symbol mean/equate in this code mean? It is not in my pic mcu quickchart. The code needs to go into a 16f870. I found this code in a delay code generator at piclist.com
; Delay = 0.5 seconds
; Clock frequency = 4 MHz
; Actual delay = 0.5 seconds = 500000 cycles
; Error = 0 %
cblock
DELAYP5
DELAYP5_1
DELAYP5_2
endc
DelayP5
;499994 cycles
movlw 0x03
movwf DELAYP5
movlw 0x18
movwf DELAYP5_1
movlw 0x02
movwf DELAYP5_2
DelayP5_0
decfsz DELAYP5, f
goto $+2
decfsz DELAYP5_1, f
goto $+2
decfsz DELAYP5_2, f
goto DelayP5_0
;2 cycles
goto $+1
;4 cycles (including call)
return
$+2 means goto the next 2 instruction.
decfsz DELAYP5_1, f
goto $+2
decfsz DELAYP5_2, f
goto DelayP5_0
If DELAYP5_1 is not zero, then go to-->goto DELAYP5_0
EDIT: you can use MPLAB to see the disassembler listing (if not mistaken), see where address it goes.
$ is the symbol for Present Location
1. goto $ will loop forever given no interrupts intervene.
2. goto $ + X will skip forward X instructions.
3. goto $ - X will skip backward X instructions.
P.S. When a delay routine is this ugly, you should just make up your own and make it paramatized so that one routine can suffice for most your long delay times.
FYI, $+11 is not the next 11 instruction but next 17. $+0B is the next 11th instruction. I've tried without a '0', i.e. $+B and it doesn't work.
You must always be away of the default radix or use definitive expressions.
If you want to skip eleven you do this:
GOTO $ + .11
GOTO $ + 0X0B
GOTO $ + 0BH
GOTO $ + B'00001011'
Or do this:
RADIX DEC
GOTO $ + 11
This is true for every single line of opcode and not just goto's.
If not mistaken, it changes the default way that the compiler interprets numerals from a base (or radix) of sixteen (hex) to a base of ten (decimal). Otherwise, it is good common practice to pre/post-fix all numerals as donniedj shows at the top of his post above.
