Decrement Routine Code
Suraj143
Active Member
Need to decrement minutes & seconds down to zero. Is my code ok?
Do_Count_Down     movf   Seconds,W
                  btfss  STATUS,Z
                  goto   Dec_Secs
                  movf   Minutes,W
                  btfsc  STATUS,Z
                  goto   Both_Zero
                  decf   Minutes,F
                  call   Split_Minutes
                  movlw  .59
                  movwf  Seconds
Show_Secs         call   Split_Seconds
                  goto   Wait_Sec_Flag
Dec_Secs          decfsz Seconds,F
                  goto   Show_Secs
                  movf   Minutes,W
                  btfss  STATUS,Z
                  goto   Show_Secs
Both_Zero         call   Split_Seconds
                  call   Split_Minutes
In the Dec_Secs path, you decrement the seconds but never decrement minutes. You also decrement minutes if both seconds and minutes are not zero. Neither of these looks correct.
What are you trying to achieve?
This is a count down timer (traditional Timer). Let say Timer value is 02:56 (2 minutes & 56 Seconds). Seconds decrement first.When seconds go beyond value zero then decrement 1 minute. Likewise it will decrement down to 00:00.
Maximum minutes = 99
Maximum seconds = 59
I see what you're doing now. Looks like it should work as expected.
However, it's a little difficult to follow jumping back and forward.
Have you considered something like,
          movf     Seconds,w            ;get seconds
          iorwf    Minutes,w            ;ior minutes
          btfsc    STATUS,Z             ;if it's zero
          goto     AllDone              ;time is up
          decf     Seconds,f            ;decrement seconds
          btfss    Seconds,7            ;has it gone negative
          goto     Wait_Sec_Flag        ;no so continue
          movlw    .59                  ;yes
          movwf    Seconds              ;so set to 59
          decf     Minutes,f            ;and decrement mins
          goto     Wait_Sec_Flag        ;continue
AllDone
          ;time has ellapsed
Hi
That's short but there is a small problem. The timeout (All Done) will achieve in next second, not in the last second :(
It will only go to AllDone when both minutes and seconds are zero.
Why do you think it will be in next second?
Edit,
Try running this in the simulator, it should dec seconds 62 times and it does.
#include "p16F84a.inc"
        cblock    0x20
Seconds
Minutes
        endc
        org    0
        movlw    1
        movwf     Minutes
        movlw    2
        movwf    Seconds
Wait_Sec_Flag
        movlw    .59                    ;yes
AllDone
        ;time has ellapsed
        end
Hi thanks for the view. This is what I mean.Every second I'm getting the 1 second flag bit.
Just load Minutes = 0, Seconds = 1.
The time out will not achieve in 1 second, It will achieve in 2 seconds. Both zero must also check after decrement seconds as well. That's what I mean :)
I think if you rearrange a little it will do what you want:
Wait_Sec_Flag
        movf   Minutes,w
        iorwf  Seconds,w
        btfsc  STATUS,2
;        movf    Seconds,w            ;get seconds
;        iorwf    Minutes,w            ;ior minutes
;        btfsc    STATUS,Z            ;if it's zero
;        decf    Seconds,f            ;decrement seconds
        movlw    .59                    ;yes
John
