DC inverters
dde2004
Hi everybody,
Does anybody have a circuit for a DC to AC inverter preferable a SINE inverter. 12VDC @ 10A is the supply.
i need to invert that to a minimum of 100VAC (a maximum of 240) @ 2A. At 50 - 60Hz
Thanx
David
dc inverter
please specify whether u need a simple inverter or a phase controlled
A simple inverter can b constructed by simply using semicondoctors while a phase controlled by SCRs also specify whether a single phase or three phase
whatever your config you will need a transformer since the inverter side can only switch to a max of 12V minus any IGBT/MOSFET forward voltage drop.
