data sheet needed boss
shivanaga said:
:eek: please send data sheat of sl100 ..........................:rolleyes:
Have you Googled for this datasheet?
Look here:
What is it?
Does the number of dots indicate something?
Here you go
  • SK100 and SL100.pdf
audioguru said:
They are ancient Asian transistors in an old metal case.
I know you know. I was curious if the OP knew. I'm still curious about all the dots.
Maybe the OP is an ancient asian just like the old transistor.
Maybe he is fixing an electronic product that is about 50 years old.
Is this diagram correct for the Rusty Nail Project on your Brand New Website?
No, the capacitor in the schematic has the wrong value. The pic is correct.
I used a 0.1 cap in one of them, and it works fine, but lower voltage to the LED. I found a 3300pf cap laying around, so I used it. Anything around 2700pf will work fine.
An LED has nearly a fixed voltage. Its current determines its brightness.
A capacitor with a value much too high lets the oscillator run at a lower frequency where the inductor doesn't work well and the circuit wastes battery current.
well if you build that one you will notice better performance, things are always going to be different if you actually build it.
Krumlink: Your site at **broken link removed** is not working.
You might be interested in an alternative site which looks a lot like yours, at **broken link removed** .
Normally it's a bad idea to point to a specific server; best to let the hosting company decide.
