D filp - Flop
lord loh.
I read in a book that the Clear and the Prest of a D Flip Flop are asynchronous inputs...
I doubt...The clear shall not propagate to the RS FF section unless the D is 0 and CLK high....and the PRESET shall not have effect unless CLK=1 and D=1....
So How really to use a D FlipFlop with Prest and Clear ?
And am I right to say that a the PRESET and Clear are a way to bypass the CLK and use the D Flip Flop as an RS Flip Flop ?
Yes, as long as the "D" & "CLK" inputs are held at static levels. Be aware of the difference between asynchronous and synchronous "Clear" and "Preset" inputs. As the terms imply, synchronous inputs only affect the Flip-Flops' output on the appropriate clock edge, whereas asynchronous inputs are level sensitive and overide the synchronous inputs.
What type number is this D flip flop? I've never known a flip flop (D, JK or one-shot) that did not have asynchronous preset and clear inputs, overriding any action regardless of their states on the synchronous inputs (D, CLK, J, K).
Dean
I was looking for a textbook circuits...
But I think that it is possible to use the asynchronous circuits by keeping static levels but still in D Flipflops, I am unable to figure this out...
If D and CLK are high, S=1 and R=0 (RS FF Section...) and now if I want to clear the FF the preset will not propagate to the flip flop...as they are and Gated...R=0 shall propagate only if CLk =1 and D=0
Am i wrong ?
Every single D and JK flip flip in 74 and 4K series that I know of have asynchronous clear and preset inputs. They override all synchronous inputs regardless of their state or the state of the outputs. The only difference is that the TTL chips usually have active LOW asynchronous inputs while the CMOS versions have active HIGH inputs.
Check the data sheet for a 7474 D or 7476 JK and you'll see how they operate.
Dean
