Cpu coin acceptor and zero delay arcade board.
Stuee123
So i have an arcade im making and using the jy-800v cpu Comparable coin acceptor, i was using the electronic side for it to allow the correct coin through and drop out the bottom and trigger a microswitch, which is connected to button 10 on the zero delay control board.
The issue is its not detecting some of the drops as its to quick.
So ive been looking at the actual pin out of the acceptor and trying to work out how to connect it to the zero delay board (this is basically 2 wired the make the connection with a button or switch.
But have no idea how, i did try a hfs2 a210dn mos relay and tried different wires but still no joy.
Could someone help me how to connect this to work please, with or without a relay.
Thanks in advance.
Coin acceptor
Zero delay board.
Relay
