Controlling stepper motor with rs232 and feedback pot
Varunme
I want to control a stepper motor with rs232 with pot feedback , will the below algorithm works ?
position = adc_rd();
portd=0x00;
main(){
          while(position =! uart_read){
           if (position < uart_read)
           { motor++};
           elseif (position > uart_read)
           {motor-- };
Yes logically it will work...
As you are taking the value from ADC and reading the value from the UART, after that you are comparing and accordingly the action will be taken...
that you can always put in the condition... that what you want to do when the UART value is not equals and when it is equals to...
Something like these
while(1)
if (position =! uart_read)
statement or condition as required
if (position == uart_read)
So, it can be modified as
while(1)
                          { motor++};
                         {motor-- };
            motor_stall();
isnt it ?
The below code works in only the first if condition , that is whatever the value I sent through UART , poftb.f1 is activated and print "1" in serial terminal
         while(1)      {
           if ( ulong =! tlong )
                          if ( ulong < tlong )
                          { PORTB.f1=1;
                          UART1_Write_Text("1");
                          break;
                          else if ( ulong > tlong )
                         {PORTB.f2=1;
                         UART1_Write_Text("2");
                         break;
            if ( ulong == tlong )
            PORTB.f3=1;
            UART1_Write_Text("3");
            break;
My intention is make a controller which adjust itself equal to the analog value sent through UART
by a stepper motor and pot ,
just for test , i just added the UART_write() and the portb bits to high when a condition is satisfied .
Hi Varun,
I am not finding any problem in logic what you have applied and i understood ur intension that wat you want exactly.
And one more thing there is no need of else if there it could be ok with else only, because either ulong<tlong or ulong>tlong.
May if possible can you monitor your both value i.e. ulong and tlong on the debugger if you have.
because i think there is some problem with your values of ulong and tlong.
