Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
I have a 12v DC (continuous) source that holds an exhaust brake on a diesel pick-up closed. The new exhaust brake requires a momentary 12v DC pulse. Is there a simple way to convert a continuous source to momentary?
A capacitor in series with a relay coil would work. That's about as simple as you could get. How long does the momentary pulse need to be? How much current does the exhaust brake draw?
Thats what I figured, just wanted a confirmation.
The draw is only the coil on a 12v automotive solenoid. It needs to pulse about a 1/2 second.
12v pos. to coil, 12v neg to capacitor then ground?
Yup. The size of the capacitor will depend on the relay. With a typical 150hm: automotive relay coil, try 4700uf or so. You may need a diode across the coil to prevent the relay from clicking again when the voltage disappears.
You should always have some margin for error. Choose a 16V one or higher because the charging system on the truck typically will float the battery up around 14.2V when the engine is running.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
