Constant Current Circuit Diagram using a tip117
jmills
hello all,
does anyone have or know where I can get a constant current circuit diagram using a tip117 transistor?
I am new to electronics, forgive me if this question lacks anything...
thanks!!!
Ψ≈Ω∞
Why do you want to use that particular transistor as a current source?
How much current? What voltage? Does it drive a grounded load?
It lacks a lot:
What current range?
What is the load? LED?
How precisely do you need to control the current?
What voltage are you starting from?
What sets the desired current? Pot? Control voltage?
What current range?
20-40 mA
variable...
3-4% ???
32 V
pot
no
reverse engineer... maybe a different part could work???
let me know if you guys need more... i will try to get it
thanks...
connect your voltage ref in parallel with the pot. Connect the -ve end of the ref/pot to the anode of a diode(1n914 etc). Connect the cathode of the diode to ground. Bias the pot/ref with a resistor to V+. Connect the wiper to the base of an npn transistor. Connect the emitter to Re (an emitter resitor) connect the other side of Re to ground. The collector of the npn is your current source, the single diode provides some Vbe compensation.
