connecting pic16f877 with a Pump
oa99733
Hi all
iam doing a senior design project, and iam trying to charge the pump so that it can provides water to the plants, my power supply will be coming from regular 110 vAC, i will be using an AC adaptor along with a voltage regulator, my idea is to connect the voltage output coming from the Pic to the power relay, and also the relay will be connected to the voltage regulator, i would like a further information about how i can make this process work.
your help is greatly appreciated
time is like gold, measure it and use it for good.
its easy in my eyes...
just contruct a pullup or pull down..cheme...
when you program to pull the output pin high it will switch the pump on..
or off..
depending what kind of relais you have..
Walter
