I have a big problem with this. I want to make aclock with Ds1307 and 16F873A. I can show thw time on lcd but when minute goes to 57 ,after that it jump to 64 and it continioued to 89 and after that minute resets and hour added . this problem occur for second and hour too.
please help me with this problem?
I wrote the program in picbasic ver2.41.
I used i2cread and i2cwrite instructions . please wirte me the correct program in picbasic.
please help me with picbasic
This is my program . Is it right or not?
define OSC 4
include"modedefs.bas"
' Set LCD Data port
DEFINE LCD_DREG PORTC
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTC
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTC
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
pause 100
SDA var PORTB.5
SCL var PORTB.7
DB0 var byte[8]
CMCON = %00000111 ' Comparators = off
pause 1000
gosub write_1307
read_1307:
' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
I2CREAD SDA,SCL,$D1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
lcdout $fe,1,"Time=",#DB0[2],":",#DB0[1]
pause 2000
goto read_1307
end
Write_1307:
' Set time & date to 15:55:00 Tuesday 6th of July 2004
I2CWRITE SDA,SCL,$D0,$00,[00,55,15,2,6,7,4,$90] ' Write to DS1307
RETURN ' Sec Min Hr Day D M Y Control
Amin Derazgisoo
define OSC 4
' Set LCD Data port
DEFINE LCD_DBIT 4
DEFINE LCD_RSBIT 1
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
pause 100
SDA var PORTB.5
SCL var PORTB.7
DB0 var byte[8]
pause 1000
gosub write_1307
read_1307:
pause 2000
goto read_1307
end
Write_1307:
Amin Derazgisoo
