Connecting ADC to Serial Port
magna
Hello,
I'm looking at connecting this chip (National ADC 0801) to the Serial Port to read some data.
Does anyone have a basic (read: real basic) circuit that I could do this with?
https://www.electro-tech-online.com/custompdfs/2004/03/ADC0801.pdf
Hopefully - I'll then be able to just read the serial port from VB to get the current voltage being put through the ADC.
Thank You,
Aaron
EDIT: This chip might be a parralel chip. Hmm <confused>
magna said:
Hello,
https://www.electro-tech-online.com/custompdfs/2004/03/ADC0801-1.pdf
Thank You,
Aaron
Yes, I think it is - it would make it complicated to read it from a serial port. Probably the simplest way is to use a PIC with an internal A2D, for a little bit of programming you get a single chip which takes the analogue input and provides an output to feed the serial port.
You can get various serial mode A2D, but these still usually require connecting to the parallel port - they don't output standard asyncronous RS232.
