...Config lines for PIC16F88 (ASM)
Martel
Hi...
I've been writing in assembler for the PIC16F84 for a while and then, switched to C.
Now, i have to write an assembler code, but for the PIC16F88 rather than the F84.
The problem i have is that the PIC16F88 has TWO config registers (CONFIG1 and CONFIG2) instead of one for the F84. For the F84 the line is simply:
__CONFIG 0xFFF1 (example)
But for the F88, i can't do anything. I tried:
__CONFIG1 0xFFE4
__CONFIG2 0xFFFE
__CONFIG 1 0xFFE4
__CONFIG 2 0xFFFE
__CONFIG 1,0xFFE4
__CONFIG 2,0xFFFE
...etc... and MPASM always reported me errors !
Does anyone know how to correctly address those two CONFIG registers ?
Thanks !
Normand Martel
St-Hubert (Montreal) Qc. Canada
I found a way to work around with my CONFIG problem:
In PIC16F88.INC, i found those two lines:
_CONFIG1 EQU H'2007'
_CONFIG2 EQU H'2008'
So i tried:
__CONFIG _CONFIG1,0xFFE4
__CONFIG _CONFIG2,0xFFFE
w/o success. I don't know why !
I finally went with:
__CONFIG 0x2007,0xFFE4
__CONFIG 0x2008,0xFFFE
And my code finally assembled !
But i still don't know why the EQU lines are not recognized !
Normand Martel
Here's the way I do it (no defines required as they're all in the 'include' file);
    __CONFIG  _CONFIG1, _DEBUG_OFF&_LVP_OFF&_BODEN_OFF&_WDT_OFF&_HS_OSC
    __CONFIG  _CONFIG2, _IESO_OFF&_FCMEN_OFF
I like Mikes way to it is so easy to type the wrong hex in a config
post your code it would be easier to help if we can see it
That's why those include files have all those defines =) To avoid the confusion, it also helps with porting to other chips which might have slightly different address structure.
