Computer controlled DC motor speed
DSGarcia
I am looking for a DC motor speed controller and need some help with my search (I am having problems coming up with the proper search terms that yield useful results). Here are my requirements:
I need to control the speed of an 1/60 HP 24VDC motor. I have 13VDC available (auto battery) but only need to turn the motor less than half speed. I would like to control the speed from a computer (using either RS-232, RS-485, or Ethernet). I can find D/A modules that produce a low current DC voltage or PWM if that would be helpful as an input for a DC motor speed controller.
I would rather find something I can purchase off-the-shelf because I don't have extra time available to devote to building/programming/testing my own controller.
Any suggestions on where to look or how to specify such a controller?
Thanks,
Dale
Thanks,
Dale
Hi
Googled RS232 motor controller and came up with plenty of results.
Cheers
Hi
Cheers
Mark,
Thanks for the help. I did not include RS232 in the search terms before because I had several different interfacing methods I could have used. However, most of the results were for stepper or servo motor controllers (which I don't need) though I did find a company named Pololu which I have to research some more. I will play around with search terms some more to see if I can get more useful results.
Thanks,
Dale
I found a Pololu DMC02 motor controller that interfaces with RS-232. To avoid a long discussion on my difficulties of finding answers and unreturned calls from various parties, let's say that I still have a few unanswered questions.
The motor is a 24 VDC motor with brushes, 1/60 HP, 45 RPM. (It is in another state so I cannot look at it until I have my solution and go to it for testing.)
I presume that the motor speed can be controlled by PWM and does not need a fixed DC voltage, correct? (The manufacturer of the equipment incorporating the motor claimed it needed a fixed DC voltage proportional to speed not PWM, but they also claimed that they use a SCR to control the voltage which doesn't make sense--I think they do not know what they are talking about).
The Pololu DCM02 delivers 2.5 amps continuous, is that enough for a 1/60 HP motor or do I need more power?
For DC motor speed controllers, what does it matter if the motor has brushes or is brushless? I have found some controllers for brushless DC motors.
Thanks,
Dale
1/60 hp is under 15 watts so that would be 24v @ 0.6 amps or so. Running at 12v should be less amps again, so I think a 2.5A controller would work it fine.
PWM averages out to something like a constant DC voltage, just you can adjust the "voltage" to set the speed you want.
Just keep in mind that its only a little motor, and running off a much lower voltage it won't have very much power.
hey look at Electronics for you magazine... it has the computer motor speed controller (i think it's a stepper motor)
if you want a DC motor speed controller i can design for you :) and i will give you the scematics and program..
my email id is karthi.amrita.cbe@gmail.com
Thanks for the information. Not that it matters at this point, but I am curious about one thing still. Some controllers mentioned that they were for brushless DC motors. What is the difference between controls for a brushless vs brushed motor?
Thanks,
Dale
Brushless DC motors often don't move at all unless you have a controller for them, they require electronics to move.
