coding a GOTO or BRA to??
MrDEB
need to include a GOTO sub routine or BRA?
the first routine is the sound. second routine checks for daylight on input B#?(photo transistor on BR2 is good choice?)disable PIR
third routine sets timer into gear for 20 minutes if daylight is present(if BR2 is high or low?)
I want to read status of photo transistor then disable PIR and enable timer if daylight is present. otherwise enable PIR and disable timer.
need to goto sub routines as needed?
how to do a sub routine??
Device = 18F1320
Clock = 8 // 8MHz clock
Config OSC = INTIO2, WDT = OFF, LVP = OFF
Include "Utils.bas"
Dim but As PORTB.0
Dim led As PORTA.0
Dim NOT_RBPU As INTCON2.7
Dim TMR1IE As PIE1.0
Dim TMR1IF As PIR1.0
Dim TMR1 As TMR1L.AsWord
Dim Speaker As PORTB.3
Dim SpeakerTris As TRISB.3
Dim Amp As PORTB.1 // turns on amp power
Dim AmpTris As TRISB.1//turns on amp pin 9
Dim Speed As Word
Dim dip1 As PORTA.0
Dim dip2 As PORTA.1
Dim dip3 As PORTA.2
Dim dip4 As PORTA.3
Dim dipRD As PORTB.0
//global variables
Dim Seed As LongWord, Tone As Byte
Dim i As Byte
//half period delays = clock speed divided by 2*frequency
Const Tones(18) As Word = (2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000,
2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000,2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000)
//interrupt routine
Interrupt MyInt()
          T1CON.0=0 //stop timer
          TMR1=-Tones(Tone) //reset period
          T1CON.0=1 //restart timer
If Tone=5 Then //if silence
   Speaker=0 //speaker off
Else //otherwise
Toggle(Speaker) //make sound
EndIf
TMR1IF=0 //clear interrupt flag
End Interrupt
Function Rand(Range As Byte) As Byte
Dim i As Byte, feed As Bit, temp As Word
For i = 0 To 7 //generate 8 bits
    Feed = Seed.30 Xor Seed.27 //make new bit
    Seed=Seed*2+Feed //shift seed left and add new bit
Next
    Temp=(Seed And 255) * Range //change Rand from 0 to 255
    Rand = Temp/256 //to 0 to (Range-1)
End Function
//main code starts here
       OSCCON = $72            //select 8MHz internal clock
       NOT_RBPU=0              //WPUs on port B
       ADCON1=$7f              //all digital
       TRISB.0=0               //make output
       PORTB.0=1 //makes pin 8 high for dip switches
       T1CON = %10000001       //pre=1
       Tone=5 //no sound please
       TMR1IE=1 //enable timer 1 interrupt
Enable(MyInt) //set interrupt going
SpeakerTris=0 //Setup Port
Seed=$12345678 //seed random number
        TRISA =%00001111          //sets your inputs on porta
While(TRUE) //repeat forever
    If dip1=1 Then //dip1 pin 1
       Speed=25
    EndIf
    If dip2=1 Then // dip 2 pin 2
       Speed=50
    EndIf
    If dip3=1 Then //dip3 pin 6
       Speed=75
    EndIf
    If dip4=1 Then //dip4 pin
       Speed=Rand(10)*15+15    //Speed = 25 to 250 random select speed
    EndIf
  checks status of BR2=daylight or dark
If PORTB.1=0 Then //if button 1 pressed add PIR=1 here
else
 PORTB.2=0 Then bra //jump to timer sub routine
For i = 1 To 200 //play 20 tones
    Tone=Rand(5) //each tone is random frequency
DelayMS(Speed) //and for 1.00 seconds
Next //end for loop
Else //otherwise
     Tone=5 //silence
     i=Rand(255) //make rand more random
EndIf //end if condition
Wend //end of while loop
//[COLOR="Red"]PIR disable routine[/COLOR]
SetAllDigital      //set digital so you can read RB0 or it will always read low
TRISA =%00000000  // if your using the junebug This is fool proof to get a led to lite
PORTA =%00000000  // Set's it all low
TRISB =%00000001  // Set's inputs and outputs
PORTB =%00000000   // Set's it all low
INTCON2.7=0        // sets wpu on portb turns on pullups on PORTB
OSCCON = $72            // 8 MHz clock
While true              // this loops it so it keeps checking
If but = 0 Then        // checks button 1 on the junebug to see if low
    led =0                 // Turns off led
    DelayMS(10)       // small debounce delay
ElseIf but = 1 Then  // checks button 1 on the junebug to see if high(BR2)
   led =1                 // Turns on led
EndIf                     // closes your IF THEN statements
Wend
End
// [COLOR="Red"]timer sub routine
[/COLOR]
Include "ISRTimer.bas"
// constant ID to 4 * 16 bit timers...
Const
   Timer1 = 0,
   Timer4 = 3
// OnTimer1 event...
Event OnTimer1()
   Toggle(PORTB.0)//pin 8
End Event
Event OnTimer2()
   Toggle(PORTB.1)//pin 9
End Event
// activate the timer module...
Timer.Initialize
// initialise the timers - refresh every 1000Hz (1ms)...
Timer.Items(Timer1).Interval = 50        // 50ms
Timer.Items(Timer1).OnTimer = OnTimer1   // timer event handler
Timer.Items(Timer4).Interval = 2000      // 2000ms, no event handler
                                         // about 20 minutes
// enable the timers...
Timer.Items(Timer1).Enabled = true
Timer.Items(Timer4).Enabled = true
// start processing all timers...
Timer.Start
// main program loop...
While true
   // this is a polled timer, not event driven - check to see
   // if it has timeout...
   If Not Timer.Items(Timer4).Enabled Then
   EndIf
   Toggle(PORTB.1)//pin 8
Wend
MrDEB
yes a go sub
have seen BRA in swordfish basic which this code is.
wondering if I need it or ?? seeing how I basically have one main program and two sub programs
main=the random sound that was originally triggered by the PIR but IR doesn't work in daylight(the PIR sensor takes RB1 LOW)
sub 1 = is it daylight or night (a photo transistor takes a designated pin LOW or HIGH?
sub 2=a timer that triggers the sound every 20 minutes if its daylight.
I would like to use a SLEEP mode to conserve battery power as well.
I got all three programs working seperatly but now I copied n pasted all together.
be80be
There is no gosub in swordfish only a goto and it will not work the way he has his code.
be80be
Do you see a gosub here
absolute
access
addressof
and
as
asm
auto
bit
bitof
boolean
bound
break
byref
byrefconst
byte
byval
case
char
 clear
clock
compound
config
const continue
dec
delayms
delayus
device
dim
disable
eeprom
else
elseif
enable
end
endif
 end
select
exit
false
float
for
function
goto
high
if
inc
include
inline
input
integer
interrupt
longint
longword
 low
mod
module
next
noinline
not
null
or
output
port
private
program
public
repeat
restore
save
select
shortint
 step
string
structure
sub
system
terminate
then
to
toggle
true
type
until
wend
while
word
xor
This is what you have to work with
be80be
Read this all about goto it's in the help for swordfish
He can do what he wants with
The Select…Case Statement
Conditional Jump
if expression goto label
The conditional jump is a special construct that can be used with a standard goto statement. For example,
if Value <> 0 goto SkipCode
high(LED)
delayms(500)
SkipCode:
low(LED)
Notice the difference in syntax when compared to a normal if…then statement. Firstly, no endif is required. Secondly, the then part of the statement is not present. You can of course use a goto inside a normal if…then statement, but the above form allows you to write the same thing more concisely.
The goto statement has a nasty reputation because of its ability to jump to almost anywhere. Some people view this lack of control as very bad. Using a goto can produce what is called spaghetti code. It gets this name because with a goto infested program, drawing a line between a goto and its destination label would look like a big plate of spaghetti. Used with care, a goto statement can be useful. However, given the highly structured nature of the compiler language, a goto statement should be used sparingly and is best avoided.
be80be
Maybe MrDeb should step back a work through a few tutorials and learn programing/swordfish from the start.
You right It Not basic it has labels like
basic and that's it more like C but you can't write c like Statement with out dim as bunch of this and that lol
And in swordfish if you use a goto it don't always do what you think it should.I would say that why the help file tells you this
Pommie
Most Helpful Member
Nearly all Basics (even VB) contain the goto function but its use is frowned upon. When you use goto you end up with spaghetti like code that is very hard to follow.
Learn to use the more structured commands like while..wend, repeat...until, for...next, if...endif etc. Also, use correct indenting. It will make your code much easier to follow.
MrDEB
I will try all the suggestions
Will research in swordfish help.
hopfully I can straighen the code out.
MrDEB
work in progress --formatting suggestions?
here is my work in progress. not pretty but still moving things around so I need no sub routines (don't want spagetti)
the tabs etc? what is the perfered layout?
I am attempting to comment and seperate the different routines.
one for sound
one for timer,
one for daylight/disable PIR night time/enable PIR
finding its diffcult to locate duplicate items as I copy n paste alot. lose track where I am at.
wish the left side gutter had a search function I don't know about. It shows some but not all??
Device = 18F1320
Include "Utils.bas"
Dim but As PORTB.2 //input for photo diode day disable
Dim led As PORTb.4//triggers PIC inplace of PIR
Dim Speed As Word
Dim dip1 As PORTA.0
//dip switch settings
Dim dip2 As PORTA.1
Dim dip3 As PORTA.2
Dim dip4 As PORTA.3
Const
     Timer1 = 0,
     Timer4 = 3
//global variables
Dim i As Byte
//interrupt routine
Interrupt MyInt()
Else //otherwise
EndIf
End Interrupt
Next
End Function
       Speed=25
EndIf
       Speed=50
EndIf
       Speed=75
EndIf
EndIf
If    but = 0 Then        // checksFOR DAYLIGHT CONDITION on pin 17 B2
      led =1                 // takes pin 10 HIGH
        led=0     // pin 10 low
//timer routine daylight condition
//Const
     //Timer1 = 0,
   //  Timer4 = 3
Event OnTimer1()
      PORTB.2=1//pin 17=
      //daylight present triggers timer
End Event
   Timer.Initialize
                                         // about 20 minutes// enable the timers...
   Timer.Start
While true
      Toggle(PORTB.4)//pin 10 for testing
EndIf
Wend
 // DARK ROUTINE PIR enabled
If     PORTB.1=0 Then //PIr ENABLED = DARK pin 9
Next //end for loop
Else //otherwise
       Tone=5 //silence
Wend
End
be80be
I don't see why you don't make three Functions
1. Sound Function.
2. PIR Function.
3. Day time Function.
It would make your code work a lot easier.
// your main code would look like this
dim day as byte
dim nite as byte
dim light as byte
dim checkPIR as byte
dim PlaySound as byte
while true
      If day = light then
      PlaySound
      elseif day = nite then
      checkPIR
      endif
      If checkPIR = true then
      PlaySound
      endif
wend
     // then just make three functions One for day and night
     // One for PlaySound
     // One for checkPIR
MrDEB
never occured to me
to do it like tht. remember I am really new at this.
I contemplated making each function a module but creating each module ??
question=you designate a byte as light etc.
this is assume is same as say light = 1. night = 2 etc.
if X = 1 then its light or X = 2 its dark
this byte syntax ???
takes less memory code or ??
looking at your code If day = light then PlaySound
playsound then is same as a subroutine? just a different way to go instead of a goto or ??
will rewrite as suggested as I have each function in separate programs.
your method looks so much easier.
be80be
It's Like this it would run the first If then as long as there lite out side.
If it gets dark it will run the night if then and the pir to start the sound
It's still all inline
MrDEB
got most of it reorganized
just what and why
dim light as byte
dim dark as byte
etc.
be80be
I'm not done I shouldn't posted that part there just place holder so I could check the code LOL here Look at this I think this will work for the PlaySound module
Module Sound
Dim Speaker As PORTA.3
Dim SpeakerTris As TRISA.3
//global variables
Dim i As Byte
Const Tones(6) As Word = (2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000)
//interrupt routine
Interrupt MyInt()
    Else                    //otherwise
    EndIf
End Interrupt
    Next
End Function
Public Sub PlaySound()
ADCON1=$70              //all digital
 While true
    If portb.0=0 Then       //if button 1 pressed
        For i = 1 To 10     //play 10 tones
            DelayMS(250)    //and for 0.25 seconds
        Next                //end for loop
    Else                    //otherwise
        Tone=5              //silence
 Wend
End Sub
End
I haven't tried it I'll post the main code can you post your latest Circuit This is mike code he done for you I just made a module out of it
be80be
It will be more like this
Device = 18F1320
Include "Sound.bas"
Dim PlaySound As trigger
Dim day As PORTX.X
Dim nite As byte
dim lite as byte
Dim checkPIR As PORTX.X
     nite=0
     lite=1
While true
      If day = lite Then
        PlaySound
      ElseIf day = nite Then
        checkPIR
      EndIf
      If checkPIR = true Then
        PlaySound
      EndIf
Wend
Just need the Function for checkPIR and it should work I think lol
Pommie
Most Helpful Member
You don't need two variable, day and night. You just define one of them as Boolean (True/False) and then use if(var=false) for the opposite variable.
Dim Day as Boolean
    if Day=True then
        //do day time stuff
    EndIf
    if Day=False then
        //do Night time stuff
    EndIf
You could also use Else for the second part.
be80be
I was kind of thinking that after I got in to it it would work better that way Thanks Mike for pointing it out. I have to redo the Sound module a little.
