Code Won't Affect PORTA
ormo
I am using the following code to multiplex a 7x8 LED array. PORTA (0x05) controls which column is on and PORTB (0x06) controls the rows for each column using the values in COL1 - COL8. PORTB changes exactly as it should to show the patterns, however PORTA remains on b'00000000'. I have also tried to us BSF and BCF to turn on individual bits in PORTA but that doesn't work either.
MULTIPLEX
    CLRF 0x05 ; Turn off columns
    CLRF 0x06 ; Turn off rows
    MOVLW b'00000001'
    MOVWF 0x05 ; Turn on column 1
    MOVF COL1,W
    MOVWF 0x06 ; Turn on rows for column 1
    NOP
    RLF 0x05,1 ; Turn on column 2
    MOVF COL2,W
    MOVWF 0x06 ; Turn on rows for column 2
    RLF 0x05,1 ; Turn on column 3
    MOVF COL3,W
    MOVWF 0x06 ; Turn on rows for column 3
    RLF 0x05,1 ; Turn on column 4
    MOVF COL4,W
    MOVWF 0x06 ; Turn on rows for column 4
    RLF 0x05,1 ; Turn on column 5
    MOVF COL5,W
    MOVWF 0x06 ; Turn on rows for column 5
    RLF 0x05,1 ; Turn on column 6
    MOVF COL6,W
    MOVWF 0x06 ; Turn on rows for column 6
    RLF 0x05,1 ; Turn on column 7
    MOVF COL7,W
    MOVWF 0x06 ; Turn on rows for column 7
    RETURN
Also, please don't make comments about using EQUs to get rid of annoying HEX codes as this is the way I prefer to program.
Thanks!
The PIC type and the PORTS initialising code would help.:)
Sorry... been a long day...
It's written for a PIC16F628A
Ports are set up as:
    BSF 0x03,5 ; Move to bank 1
    MOVLW 0x00
    MOVWF 0x85 ; Set PORTA to all outputs
    MOVWF 0x86 ; Set PORTB to all outputs
    BCF 0x03,5 ; Move to bank 0
Indeed - have you set PORTA to digital instead of analogue/comparator inputs ?
Have you set the port direction to outputs ?
Have you remembered that certain lines on PORTA are open drain or input only ?
    [B]BSF 0x03,5 ; Move to bank 1[/B]
    MOVLW 0x00
Is this correct.????? BSF 0x03,5 ; Move to bank 1
Woops I am looking cross eyed.:o
I know you prefer to code using the hex port/reg addressess, but its a little confusing.
Yeah, that bit of code is correct. 0x03 is the STATUS register and setting bit 5 moves us to bank 1.
What about the post I made above about setting the PORTA to digital and turning off comparators/analogue etc ?
Well it's an utterly silly way to carry on - use the MicroChip include file - you're just going to make silly mistakes doing it like that, and people mostly won't bother looking at your code.
Sorry about that, I have now edited the code using the PORTA/B equates etc.
Ran it in my SIM. only time PORTA is called [COL] is COL1.
It would appear the MULTIPLEX code for PORTA is all screwed up.
I'll look thru it.
EDIT: Look at this
MULTIPLEX
    CLRF PORTA ; Turn off columns
    CLRF PORTB ; Turn off rows
    MOVLW b'00000001'
    MOVWF PORTA ; Turn on column 1,
   [B] MOVF COL1,W;load COL1 into W, BUT [COL1] is empty.!
[/B]
EDIT2:
The rotate is clearing PORTA. see image
hi ormo,
I would recommend that you consider switching to the more conventional ways of writing your code, yours takes me back to the 1970's!.:), its very difficult to follow.
A couple of observations about your code,
You don't have a delay between subsequent rows.
You may shift a 1 bit into whichever port 0x05 is as you don't clear the carry flag.
I also agree with all the above, use the register names. If you write bsf 0x23,5 with the comment "set the carry flag" I am not going to go check the data sheet to see if that is correct. If you write bsf STATUS,C then I know it is correct.
Include me among them
...and people mostly won't bother looking at your code.
Nigel is right; I did not.
Thanks to all for the advice - it's all going good now ;)
hi ormo,
Can you tell us what changes you made to the code.? in order to make it work.:)
hi ormo,
Let me guess. It's the disabling of analog comparators?
movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
From Nigels excellent tutorials: "Lines 5 and 6 are specific to the 16F628, 'movlw 0x07' means 'MOVe the Literal value 7 into the W register', the W register is the main working register, 'movwf CMCON' means 'MOV the value in W to File CMCON', CMCON is a register in the 16F628 that is used to select the operation of the comparator hardware. So these two lines set CMCON to 7, this disables the comparator, and makes their I/O lines available for general use."
Don't know the adress of CMCON, but I think that issue has been highlighted earlier...
Good guess by me then (on two posts above) :p
Glad you got it sorted :)
How disappointing, I thought you were inspired, not just guessing.:rolleyes:
Regards
Thanks 'ormo' your feedback will help others.:)
Well without spending too much time trying to translate his code I had a quick glance over and decided I couldn't see anywhere that he'd turned off the comparators and/or A2D so thought it would be worth putting the solution that catches most of us out at one point or another up.
I think his next question will be about RA4 (and possible RA5) not working properly ........ ;)
