Code doesn't function in application. PIC 16hv616.
midsha1628
Hello all!
Thank you for viewing my question.
In my code, which is listed below, I can not seem to figure out why it does not work in the application(in the circuit, which spins a shaft w/ a magnetic sensor reading pulses) but sims fine with mplab v8.0. Note: Using PIC 16hv616.
I am using timer1 with gate to time the high time of the pulse, and compare this(count_5) to a threshold (average of counts 1-4). I have it branch to the three possible results (over, equal, or less) to light an LED telling me what it is doing based on the result.
In the application it always goes to the red LED even if the time is greater(green LED). As rpm increases the red led should light as time will get shorter when compared to the threshold and the green LED should come on as the rpm decreases since time is greater. Yellow LED should light when the rpm stays the same. Can anyone find something in the code that would keep this from working in the application?
Thank you.
-B
	radix	DEC
	list	p=16hv616	; list directive to define processor
#include <p16hv616.inc> 	; processor specific variable definitions
	__config _CP_OFF & _WDT_OFF & _BOR_OFF & _MCLRE_ON & _PWRTE_ON & _IOSCFS_4MHZ & _INTRC_OSC_NOCLKOUT
FIRST_DIVIDE macro 		;COUNT_1, COUNT_2 ;COUNT_1+1 COUNT_2+1
	movf	COUNT_1,W
	addwf	COUNT_2, W
	movwf	COUNTA
	btfss	STATUS, C
	goto	$+2
	incf	COUNT_1+1, F
	movf	COUNT_1+1,W
	addwf	COUNT_2+1,W	;RESULT OF THE ADD IS PLACED INTO THE WREG.
	movwf	COUNTA+1	;WILL NOT TEST FOR HIGH BIT CARRY SINCE TIME PER PULSE WILL NOT BE THAT LONG.
	rrf	COUNTA+1, F
	rrf	COUNTA,F
	endm
;THIS CODE TAKES THE SUMS OF TWO 16 BIT NUMBERS AND DIVIDES BY TWO AND STORES THEM INTO REGISTER, 'COUNTB'.
SECOND_DIVIDE macro
	movf	COUNT_3,W
	addwf	COUNT_4, W
	movwf	COUNTB
	btfss	STATUS, C
	goto	$+2
	incf	COUNT_3+1, F
	movf	COUNT_3+1,W
	addwf	COUNT_4+1,W	;RESULT OF THE ADD IS PLACED INTO THE WREG.
	movwf	COUNTB+1	;WILL NOT TEST FOR HIGH BIT CARRY SINCE TIME PER PULSE WILL NOT BE THAT LONG.
	rrf	COUNTB+1, F
	rrf	COUNTB,F
	endm
THRESHOLD_1 macro
;THIS CODE TAKES THE SUMS OF TWO 16 BIT COUNTS, (A+B), AND DIVIDES BY TWO AND STORES THEM INTO REGISTER, 'THRESHOLD1'and count0 and count1.
	movf	COUNTA,W
	addwf	COUNTB, W
	movwf	THRESHOLD1
	btfss	STATUS, C
	goto	$+2
	incf	COUNTA+1, F
	movf	COUNTA+1,W
	addwf	COUNTB+1, W
	movwf	THRESHOLD1+1
	rrf	THRESHOLD1+1, W
	movwf	THRESHOLD1+1
	movwf	COUNT1
	rrf	THRESHOLD1, W
	movwf	THRESHOLD1
	movwf	COUNT0
	endm
PULSE_SHIFT macro
	movlw	00H
	movwf	COUNT_4
	movf	COUNT_3,W
	movwf	COUNT_4
	movf	COUNT_2,W
	movwf	COUNT_3
	movf	COUNT_1,W
	movwf	COUNT_2
	endm
;VARIABLES
COUNT_1	equ	0X20
COUNT_2	equ	0X22
COUNT_3	equ	0X24
COUNT_4	equ	0X26
COUNT_5	equ	0X28
COUNTA	equ	0X2A
COUNTB	equ	0X2C
THRESHOLD1 equ	0X2E
COUNT	equ	0X30
COUNT1	equ	0X32
COUNT0	equ	0X34
;RESET_VECTOR CODE 0x000 ; processor reset vector
	page
	org	0
	goto	start
MAIN	code
start
;INITIALIZATION (PORTA = GPIO)
	errorlevel -302
	bsf	STATUS,5
	clrf	ANSEL
	movlw	B'00010000'
	movwf	TRISA
	movlw	B'10000011'
	movwf	OPTION_REG
	movlw	B'010000'
	movwf	WPUA
	bcf	STATUS,5
	banksel	PORTA
	clrf	PORTA
	movlw	B'11000001'	;USING TMR1 GATE. ;SET UP TIMER1 REGISTER FOR PRESCALER OF 1:1, INTERNAL CLOCK, BIT '0' STARTS/ STOPS TIMER1.
	movwf	T1CON
	movlw	B'00000010'
	movwf	CM2CON1
	errorlevel +302
;MAIN PROGRAM STARTS HERE
;RESETS ALL 'COUNT' REGISTERS TO ZERO AT START OF PROGRAM.
	movlw	00H
	movwf	COUNT
	movlw	00H
	movwf	COUNT_1
	movlw	00H
	movwf	COUNT_2
	movlw	00H
	movwf	COUNT_3
	movlw	00H
	movwf	COUNT_4
	clrf	TMR1L
	clrf	TMR1H
HA
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	TMR1H, W
	movwf	COUNT_1+1
	movf	TMR1L, W
	movwf	COUNT_1
	clrf	TMR1L
	clrf	TMR1H
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	TMR1H, W
	movwf	COUNT_2+1
	movf	TMR1L, W
	movwf	COUNT_2
	clrf	TMR1L
	clrf	TMR1H
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
FIRST_DIVIDE
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	TMR1H, W
	movwf	COUNT_3+1
	movf	TMR1L, W
	movwf	COUNT_3
	clrf	TMR1L
	clrf	TMR1H
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	TMR1H, W
	movwf	COUNT_4+1
	movf	TMR1L, W
	movwf	COUNT_4
	clrf	TMR1L
	clrf	TMR1H
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
SECOND_DIVIDE
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	TMR1H, W
	movwf	COUNT_5+1
	movf	TMR1L, W
	movwf	COUNT_5
DAL
THRESHOLD_1
PULSE_SHIFT
	clrf	TMR1L
	clrf	TMR1H
	btfss	PORTA,RA4
	goto	$-1
	bsf	PORTA,RA1
	bcf	PORTA,RA0
	nop
	bcf	PORTA,RA2
	nop
	bcf	PORTA,RA5
	movf	COUNT_5+1,W
	subwf	THRESHOLD1+1,W
	btfss	STATUS,Z
	goto	$+2
	goto	CAB
	movf	COUNT_5+1,W
	btfsc	STATUS,C
	goto	LESS		;LESS THAN,
	goto	GREATER		;GREATER THAN
BAB
	movf	THRESHOLD1,W
	subwf	COUNT_5,W
	btfsc	STATUS,C
	goto	GREATER
	goto	LESS
CAB
	movf	COUNT_5,W
	subwf	THRESHOLD1,W
	btfss	STATUS,Z
	goto	BAB
	goto	EQUAL
LESS				;RED LED
	bsf	PORTA,RA0
	movf	COUNT_5,W
	movwf	THRESHOLD1
	movf	COUNT_5+1,W
	movwf	THRESHOLD1+1
PULSE_SHIFT
	goto	WAKE
EQUAL				;YELLOW LED
	bsf	PORTA,RA2
	movf	COUNT_5,W
	movwf	THRESHOLD1
	movf	COUNT_5+1,W
	movwf	THRESHOLD1+1
PULSE_SHIFT
	goto	WAKE
GREATER				;GREEN LED
	bsf	PORTA,RA5
	movf	COUNT_5,W
	movwf	THRESHOLD1
	movf	COUNT_5+1,W
	movwf	THRESHOLD1+1
PULSE_SHIFT
	goto	WAKE
WAKE
	btfsc	PORTA,RA4
	goto	$-1
	bcf	PORTA,RA1
	movf	COUNT_5+1,W
	movwf	COUNT_1+1
	movf	COUNT_5+1,W
	movwf	COUNT_1+1
	movf	TMR1H, W
	movwf	COUNT_5+1
	movf	TMR1L, W
	movwf	COUNT_5
	clrf	TMR1L
	clrf	TMR1H
FIRST_DIVIDE
SECOND_DIVIDE
	goto	DAL
	end
