ceramic caps for tesla coil?
What kind of ceramic caps? Do you have links? I have heard of them being used, but they are not usually all that efficient. You will need to read up on all the specs, just to be sure. I'm afraid I never got past the low-cost homemade caps, so I probably won't be able to help with the professional caps. I'm sure other members here can help a lot, though.
Regards
https://www.ebay.com/sch/i.html?_nk...pg=50&LH_BIN=1&_sop=15&_osacat=4662&_from=R40
im using a 15kv transformer so peak is about 22kv. i can buy a few 30kv caps and put them in parallel to reach my goal of 8.6nF
The problem with most professional caps for Tesla coils is their efficiency. Most capacitors are very lossy at high frequencies, so it is difficult to find ones that will work properly. Again, I don't really have much experience with MMCs, but other members here might. I'm just as eager to get an answer as you are :D
Use polyester or polypropylene. Try running it with ceramics for a few minutes, then turn it off and feel how hot they get. Then try the same thing with poly caps. HUGE difference.
Oh, wait - 22KV? Nevermind, dunno from 22kv caps.
how about these? i can make an MMC. they are only rated for DC there is no AC rating for them? i can afford these.
this is the data sheet for them:
If you're building an AC-powered tesla coil, these DC caps will not work. They are intended for DC and may explode if high voltage AC was applied to them. you could, however, switch your TC over to DC, but it would require a few extras (like high-voltage rectifiers).
Metallized polyester caps aren't polarized, they aren't constructed like electrolytics. The dielectric's a layer of plastic film, not an oxide, and it works both ways. Note that there's no polarization, even in the spec sheet. Yes, it says "kVdc" on it, but that's just the dc rating.
Unfortunately, the AC voltage rating is always less than the dc voltage rating on poly caps, and usually by quite a bit. https://www.electro-tech-online.com/custompdfs/2011/11/ABD0000PE111.pdf
Unfortunately, the AC voltage rating is always less than the dc voltage rating on poly caps, and usually by quite a bit. https://www.electro-tech-online.com/custompdfs/2011/11/ABD0000PE111-1.pdf
so, your pretty sure with a good deal of certainty that they will work? i can order 16 for bout 40$ to make a MMC with a DC rating of 30kvdc 8.8nF. im using 15kv transformer so peak AC is about 22kv
Try a HV mica capacitor (example: **broken link removed**). You won't find a lower esr for low capacitance.
John
No, I'm just sure they aren't polarized. I've seen poly cap AC ratings that were one-TENTH the DC rating. Without telling you that number, I'm afraid those things are still a crapshoot.
Yes, doorknob caps will work, that's what's usually used.
If you can afford doorknob capacitors, then yes, they'll work great. They are very popular in Tesla coil applications, as they have excellent insulation and a low ESR. They are also not likely to lose energy, even at very high frequencies. I simply was never able to afford them, as they often cost $20-$100 a piece :p
EDIT: Just looked at the link. You'll need 4 of them in parallel, so that means you'll have to buy two sets as shown there on ebay.
An empty beer bottle full of salt water wrapped with aluminum foil on the outside makes a better TC cap than ceramic caps and these are not real efficent.
This is the capacitor you need. This guy sells these in lots of 20, 40, 100, he has several auctions and relists then every week. He has been selling these for many years I bought 24 caps for my 4" TC. Wire them is series to get 40K volts then wire those in parallel to get the uf rating you want.
I just sold 30 ceramic caps on ebay because they don't work well on tesla coils. Very high loss TC output sucks.
WHY did I receive a message in email that someone replied to this thread? Nothing new here this was 12 years ago.
Are you sure it was this thread? There was another similar thread that came up recently....
I just checked, there were no spammer posts or anything that would have triggered a notification. Also, how'd you end up in 2024? I'm still back here in 2017!
It came up in my email just like this one did. I clicked the link and here I am on the forum.
