CC - CE cascade
polinski
Hello everyone.
Im a newbie in electronics and i wanna study how a CC-CE cascade works.
I read some books for the formulas and the theory about it, but im confused a lil bit.
If i start with only the CE amplifier i have this circuit:
https://imgur.com/KTW7j
with random values
If i wanna write kirchoff formulas, there are:
Rc + Re = (Vcc - Vce)/Ic
where Vce = (Vcc)/2
and thevenin conditions are:
Rth = R1 // R2
Vth = (Rth/R1)*Vcc
and also:
Vth = Ib Rb + Vbe + Ic Rc with Ic ≈ β Ib
at least:
Av = - Rc/Re
However I have some problems with kirchoff formulas about CC-Ce cascade :confused:
There is my pspice model (gave by school):
https://adf.ly/3Z2SC
(with random values again)
-Vcc + (Vce)2 + I(re2)Re2 =0
where (Vce)2 is for the new resistor.
how must i continue?
i hope someone will help me, thanx.
Why is your schematic as big as my neighbourhood?
I cropped it and used Ohm's Law and simple artithmatic to calculate the voltages.
Ah sorry, i thought it was ok.
By the way, my problem is for cascade CE-CC in this picture:
https://imgur.com/4LqyD
Supposed R1,R2,Re and Rc with a value, i must find Re2, i have written these formulas:
- Vcc + Vce + Re2 *I(Re2) = 0
-Vcc + Rc *I(Rc) + Vbe + Re2 I(Re2)=0
are they correct?
Your equations looks good.
Ie1*Re + Vce2 = Vbe+ Ie1*Re2
Or
VRe2 = Vcc - (Ic2 + Ib1)*Rc - Vbe1
And don't forget that current that is flow through Rc is equal to:
IRc = Ic2 + Ib1
n p n junction
I want to understand how to 'put' the CE + CC configuration in cascade on a breadbord :/ im using a virtual one like that:
https://imgur.com/IS3Z9
I think i must use also the oscilloscope for misurating Vin, Vout and Av = Av1 *Av2
Yes I understand this, but what is the physical type of the BJT you are using in the breadboard (2N2222) ??
It really helped to me! Thanks a lot!
Another 2 questions:
1. in that figure i dont see the capacitor Cin, its normal or i must put it too on breadbord?
2. In this CC+CE configuration if i wanna find every resistor, i must write kirchoof formulas.
We write in the last topic some of them.
i can find Re2, supposed that Vce = Vcc/2 ----> Re2 = Vcc/(2*I(re2))
i cand find Rc so: Rc = (Vce/2I(Rc) ) - Vbe/I(Rc)
supposed Vbe = 0,7 Volts.
Is that correct?
[im trying also to write formulas for R1 and R2]
FOR THE CAPACITOR i use in every simulation 100 nF, i think its ok.
what do you think about all this? :)
Yes you need to place Cin capacitor in the breadbord
See the attach file.
Is that correct?
Well, you have done a small error in Rc equation
-Vcc + Ic*Rc + Vbe + Ie2*Re2 = 0
Rc = (Vcc - Vbe - Ie2*Re2)/Ic
But we can assume that your power supply voltage is equal 9V and start to choose the component value.
Re2 = 4.5V/4.5mA = 1KΩ
Vc1 = Ve2 + Vbe = 4.5V + 0.65V = 5.15V
Rc = (Vcc - Vc1)/ ( Ic1+Ib2 ) ----> assume Ic1 = 1mA we end up with
Ib2 = Ie2 / (hfe+1)
Hfe from the data sheet
https://www.electro-tech-online.com/custompdfs/2011/11/PN2222A.pdf
I chose Hfe_min = 50 for Ic>1mA
Rc = ( 9V - 5.15V) / (1mA + 90uA) ≈ 3.9KΩ
but if you want more standard resistor value, for example 10K, no problem at all.
Ic1 + Ib2 = (Vcc - Vc1)/Rc = 3.85V/10K = 385µA
I want the voltage gain to be equal 10 times.
Then Re = Rc/5 ≈ 2.2K
Vb = Ie*Re + Vbe = 350uA*2.2K + 0.65V = 1.42V
To find voltage divide resistor values we normal use this equations
R1 = ( Vcc - Vb) / ( 11*Ib)
R2 = Vb/(10*Ib)
But i chose R2 = 10K and
IR2 = 1.42V/10K = 142µA
R1 = ( 9V - 1.42V)/ ( 142uA + 10uA) = 49K ≈ 51K
Cin > 0.16/( F * Rin) = 1uF
F = 20Hz
Rin = R1||R2||(Hfe+1)*Re = 7.7K
I hope this helps
  • ce+ccx.zip
    ce+ccx.zip
Yes now i can watch your pic.
I noticed that you gave some random value, i think its ok
By the way, Cin that i use more, its 100 nF or 150 nF it depends.
IS Rin = R1||R2||(Hfe+1)*Re = >
1/Rin = 1/R1 + 1/R2 + 1/(hfe+1)*Re ?
For you Vb is Vbe?
The size of a capacitors is selected that Xc is much smaller then resistance of a cooperating resistor at the lowest frequency of operation Xc=0.1*R.
Xc = 1/(2*PI*F*C)=0.16/(F*C)
C = 0.16/(F*R)
So for Cin = 100nF the signal frequency must be greater then 160Hz
For you Vb is Vbe?
Yes this symbol "||" mean connected in parallel resistors.
Vb is the voltage at base of a BJT
Vb = Ie*Re + Vbe
