What I wanted to try is to replace a mess of components as seen in this page: http://wiki.pcengine.info/pmwiki.php?n=Hardware.Tennokoe2 second image. The SRAM chip is on the right side of the board and the mess of parts are on the left side. It uses 2 voltage sensing chip (looks like transistors), 1 darlington transistor, and 1 odd diode plus few resistors and capacitors to handle voltage switching between the 3v battery and 5v mains. When the game system is shut off, the circuit is supposed to switch over to batteries.
I am trying to shrink that board and if the super cap can work, it would cut about 1/3 of the board out. The cap charges normally from 5v source when the system is on, and when it is off, the cap keeps the SRAM powered and a diode prevents the cap from powering the whole system. I forgot in the above picture a resistor (10k probably) to pull up /CE line to capacitor's + end to put the chip in standby when there's no external activity.
Would that work or would a 2k SRAM still need convoluted power switching logic to preserve the data?
PS has the SRAM changed in power requirement in the last 20 years? If modern 2k SRAM that is pin compatible but has lower power requirement in standby, I may need to swap the chip too! The also shows a large 64 pin chip, that is a custom chip that handles the communication from the host system and controls when SRAM can be read or written to. Since it's custom and propriety, this would have to stay intact for now.
