Can subroutines be located outside of the 'End' statement
Flamer1
Can subroutines be located outside of the last 'End' statement in a
program? Here is an example of a subroutine DATAIO defined outside
of the end statement
TRISB = 0
START:
PORTB.1 = 1
Pause 100
Goto DATAIO
PORTB.0
Pause 100
Goto START
End
DATAIO:
Serout PORTB.1, 4, ["Hello World!"]
Pause 100
Return
i'm writing a program right now that will be a large program once it's done. as it is, it's looking pretty sloppy with a bunch of Goto statements scattered across the program. i'd like to make it more readable by including the subroutines at the end, if possible
or put your sub-routines at the begining???
like.....
goto mainbody
;********sub1********
bsf porta,0
return
;********sub2********
bsf porta,1
return
;********main body*****
mainbody
I will appologise for the lack of imagination with the code :roll:
or create a file and then you include it. SO that it looks neat and if another program is able to use them as well you don't have to re-write the code, but use the include comand.
Ivancho
Jep use a project and then include all the files. can them *.inc but rember that if you include a file it become at that place in your asm FILE so hold that in mind.
And use CALL for a subroutine and not a GOTO. Because a CALL gif you a stack all the time so you can use it all the time.
Cya
It looks like he is using Pic Basic, so he couldn't easily use a CALL instruction or deal with .asm include files.
