No; a toroid is supposed to be inherently free of field leakage.Will a 30 turn toroid with a LED light work as a microwave leakage detector?
I have noticed when I stand to the right of our kitchen microwave oven to wait 45 seconds for something to heat up it makes me feel dizzy. This morning I felt dizzy again soon as the microwave started so I got away from it. Is it possible for a factory microwave to leak???
The primary effect of leakage would be a feeling of warmth, as the RF is dissipated in your skin as it would be in food, to cause heating. I don't think dizziness would be a symptom??
If there is no physical damage to the microwave and the door closes correctly, leakage seems unlikely.
Any significant leakage would likely swamp any WiFi device, as they are on similar frequencies.
Is you phone WiFi signal affected by starting the microwave with the phone close by, compared to the signal in the same location with the microwave off?
How can I test our factory microwave for leaking microwaves?
I did once a 5cm diameter loop of wire with a tiny led at its ends. Does light up next to a mobile phone. -uncalibrated reading-Will a coil of wire work as a transformer to produce a voltage to light up an LED?
I have 500 turn coils in ferrite that light up an LED when I put them near my 200KHz tooth brush charger. LED does not light up anywhere near the microwave oven. I see several $9.99 microwave oven leak detectors for sale online.
If the microwave oven does not leak a detector will read 0 it needs no markings. What I read online says, factory microwaves do not leak so don't question it.Would you buy a ruler with no markings on it?, so why buy a toy leakage detector with no indication of it's calibration?.
No, completely untrue - all ovens 'leak', it's just a question of how much - which is why a correctly calibrated meter is required.If the microwave oven does not leak a detector will read 0 it needs no markings. What I read online says, factory microwaves do not leak so don't question it.
Hardly surprising. Even if there were any leakage, all those turns have so much impedance that any microwave energy would have a struggle reaching the LEDLED does not light up anywhere near the microwave oven.
Found something similar, but do not know why a second diode.I did once a 5cm diameter loop of wire with a tiny led at its ends. Does light up next to a mobile phone. -uncalibrated reading-
About 15 cm of any wire, soldered a tiny surface mount LED at the ends, bent to form a circle.
Page 75 of this pdf for a diy microwave leakage detector https://www.worldradiohistory.com/AUSTRALIA/ETI-Australia/70s/ETI 1979-07 July.pdf - not a calibrated thing but will tell you if a leak exists.
And yes, all microwave ovens leak - ours knocks out the wi-fi connection occasionally.
No.Will a coil of wire work as a transformer to produce a voltage to light up an LED?
