calibrating lm35 analog value to degree Celsius using 8051
i am working on a project which objective is to measure the temperature of surroundings..using AT89s52 micro-controller and ADC0804 for A to D conversion.. the temperature meant to be shown on LCD..
after doing some research i managed to read ADC values coming from the LM35 and displaying it on LCD..
now... finally the tricky thing which i fails to understand...( may be because i won't get any useful material to study)..
so i want to know...
- how to convert the ADC value to corresponding Degree Celsius
-how the step change get affected by varying the Vref/2 and how this affect my code..
My circuit Diagram and CODE( iam getting the varying ADC value on LCD as i change the temperature) is given as..
#include<reg52.h>
#include"lcd.h"
void delay1(unsigned int);
sbit chipsel =P1^4;
sbit write = P1^5;
sbit intr = P1^7;
sbit readAD = P1^6;
unsigned int val=0,i,j;
void conv();
void read();
void main()
init();
while(1)
conv();
read();
cmd(0x01);
op(val);
delay(1);
void conv()
chipsel = 0; //Make CS low
write = 0; //Make WR low
write = 1; //Make WR high
chipsel = 1; //Make CS high
while(intr); //Wait for INTR to go low
void read()
readAD = 0; //Make RD low
val = P3; //Read ADC port
readAD = 1; //Make RD high
void delay1(unsigned int y)
for(i=0;i<y;i++)
for(j=0;j<1275;j++);
the LCD source code is in the attachment with the circuit diagram
  • temp.c
    temp.c
  • lcd.h
    lcd.h
I see no software person has answered you. I am a hardware person.
Get the data sheet for the LM35. It has a temperature to voltage graph.
ADCs in micro controllers do not measure voltage directly. In 8 bit mode they measure from 0 to 255. Where 0=0 volts and 255=vref.
You need to think; at freezing=some voltage from the LM35 and a certain ADC reading.
At boiling= a LM35 voltage and a ADC reading. (based on the value of VREF)
With some math you should be able to connect temperature to ADC reading.
thanks for your help sir!
i am a noob here and this graph doesn't make me any sense.. its from LM35 Data sheet
i did read some tutorials.. but those are not complete tutorial.. they don't explain what should be the voltage at Vref/2 pin of ADC0804 . and how the step change changes by varying that Vref/2 voltage..
all i get to know that LM35 output voltage changes about 10mV per degree rise in temprature...
all this Vref thing confusing me
