c programming problem
kapcai
hi geng...
i kind of new here...
this is my programming...
include <p18f4520.h>
#include "delays.h"
#pragma config PWRT = OFF
#pragma config MCLRE = ON
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = OFF
void msDelay(unsigned int itime);
void AD_ISR(void);
void chk_isr(void);
void initial (void);
void forward (void);
void backward (void);
#pragma code High_Priority_Int = 0x0008
void High_Priority_Int(void)
chk_isr();
#pragma code
#pragma interrupt chk_isr
void chk_isr(void)
if (PIR1bits.ADIF==1)
AD_ISR();
void main(void)
TRISB = 0;
TRISC = 0;
TRISD = 0;
PORTB = 0;
TRISAbits.TRISA0 = 1;
ADCON0 = 0b01000001;
ADCON1 = 0b10000100;
PIR1bits.ADIF=0;
PIE1bits.ADIE = 1;
INTCONbits.PEIE =1;
INTCONbits.GIE = 1;
msDelay(100);
while(1)
ADCON0bits.GO = 1;
msDelay(100);
void AD_ISR(void)
PORTD = ADRESH;
msDelay(130);
if (PORTB=0)
initial();
else if (PORTB<PORTD)
forward();
else if (PORTB>PORTD)
backward();
else if (PORTD=PORTB)
PORTC = 0;
PIR1bits.ADIF=0;
void initial (void)
void forward (void)
unsigned int i, j;
for (i=0;i<itime;i++)
for (j=0;j<135;j++);
my problem is , this program would not jump to initial,forward and backward subroutine.... :confused::confused::confused:
You need a goto at the ISR vector,
#pragma code high_vector=0x08    //setup the ISR vector
void high_interrupt (){
  _asm GOTO high_isr _endasm    //jump to interrupt handler
#pragma code
void high_isr(){
BTW, if you type [code] before your code and [/code] after it then it will keep it's formatting.
i'll be looking into it...
the funny thing its working if i'm writing my program like this
void AD_ISR(void)
PORTD = ADRESH;
msDelay(130);
if (PORTD==0b00000000)
PORTC = 0x55;
else if(PORTD>=0b00000001&&PORTD<=0b00011001)
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
msDelay(100);
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
PORTB = PORTD;
msDelay(3000);
else if(PORTD>=0b00011010&&PORTD<=0b00110011)
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
msDelay(100);
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
msDelay(100);
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
msDelay(100);
PORTC = 0x66;
msDelay(100);
PORTC = 0xCC;
msDelay(100);
PORTC = 0x99;
msDelay(100);
PORTC = 0x33;
PORTB = PORTD;
msDelay(3000);
PIR1bits.ADIF=0;
but... when i'm adding
void AD_ISR(void)
PORTD = ADRESH;
msDelay(130);
if (PORTB=0)
initial();
forward();
backward();
PORTC = 0;
PIR1bits.ADIF=0;
it just didn't work.. not reading the subroutine...
by the way this program is to move my stepper motor to certain degree when certain voltage input given
btw..
what do you means by type
btw..
If you click on the # icon before pasting your code, or type [code] ahead of your code and [/code] after it, your code will look nice and properly formatted (provided it was that way to begin with) like this:
#include <system.h>
#pragma	CLOCK_FREQ	8000000
#pragma DATA    _CONFIG1H, _INTIO2_OSC_1H
#pragma DATA    _CONFIG2H, _WDT_OFF_2H
#pragma DATA    _CONFIG3H, _MCLRE_ON_3H
#pragma DATA    _CONFIG4L, _LVP_OFF_4L
void main()
    osccon = 0x72;          //set int osc to 8MHz
    adcon1 = 0b01111111;    //all digital
    trisa = 0;              //set data directions
    trisb = 0b00010000;
    while(1){
        latb.RB1 = 1;
        delay_s(1);
        latb.RB1 = 0;
        delay_s(1);
instead of looking like this unreadable mess:
#include <system.h>
void main()
trisb = 0b00010000;
while(1){
latb.RB1 = 1;
delay_s(1);
latb.RB1 = 0;
delay_s(1);
