C program to reverse a number.
Parth86
Hi
I am able to write program that print reverse number example 10 9 8 7 6 5 4 3 2 1
C:
#include <stdio.h>
int main()
    int i =10;              / decleration of variable
    while(i>=1)
        printf("%d \n", i);
        i--;
    return 0;
Now I want to write c program that reverse the number entered by the user and then prints the reversed number on the screen. For example if user enter 123 as input then 321 is printed as output. I have seen some program on internet but I don't understand the logic behind program. so looking help with basics
Something like,
    unsigned char i,str="12345";
    for(i=0;i<5;i++){
        printf("%d \n", str[4-i]);
You can do a for that decrements but it's a little messy with unsigned numbers.
#include  <stdio.h>
int main(void)
{ __int64 x=76543210;
  __int64 y=0;
  __int64 g=0;
  while(x>0)
  { g=10*g+9;
    y=10*y+x%10;
    x=x/10;
  printf("x = %d\n", x);
  printf("y = %d\n", y);
  printf("g = %d\n", g);
  return 0;
x = 0
y = 1234567
g = 99999999
Here's a quick reverse integer function with comments.
C:
int reverse(int x) {
    int temp, digit, res = 0;
    while (x != 0) {
        // mod 10 gets digit
        digit = x % 10;
        // shift previous result over and add the newest digit - store temp for overflow comparison
        temp = res * 10 + digit;
        // prevent int overflow by checking if reverse operation is the same
        if ((temp - digit) / 10 != res)
            return 0;
        // not overflow, so store new result for next interation
        res = temp;
        // remove digit from original number, shift down
        x /= 10;
    return res;
I said that I have seen many programs on internet and I am just asking for basic understanding. suppose how do you do manually than using by program. so I think I have to understand what's happening and than I want to go with program.
That's why I added the code comments, for understanding. Its just maths. It makes me think you don't understand what a modulo operation is?
The method is to do one digit at a time from the integer until nothing is left.
From the input number, get the smallest to biggest digit using modulo 10, and divide by 10 to shift the integer down.
For the reversed result, you do the opposite. Use the digits acquired above but add them to the result after multiplying by 10 for each one.
Example 345, need to get the 5, use module 10. Then need the 4, so take 345/10 = 34, and module 10 = 4. Need the 3, so take 34/10 mod 10 = 3.
For the result you just do the opposite with those numbers. 5, then when you have the 4, take 5*10+4=54, when you have the 3, 54*10+3.
Example: Start x = 345, res=0
First loop:
  • digit = x % 10 = 5
  • temp = res * 10 + digit = 0*10 + 5 = 5
  • if ((temp - digit) / 10 != res) = if ((5-5)/10 != 0) = if (0!=0)
  • res = temp = 5
  • x/=10 = x/10 = 345/10 = 34
Second loop:
  • digit = x % 10 = 34%10 = 4
  • temp = res * 10 + digit = 5*10 + 4 = 54
  • if ((temp - digit) / 10 != res) = if ((54-4)/10 != 5) = if (5!=5)
  • res = temp = 54
  • x/=10 = x/10 = 34/10 = 3
Third loop:
  • digit = x % 10 = 3%10 = 3
  • temp = res * 10 + digit = 54*10 + 3 = 543
  • if ((temp - digit) / 10 != res) = if ((543-3)/10 != 54) = if (54!=54)
  • res = temp = 543
  • x/=10 = x/10 = 3/10 = 0
No forth loop because x=0
return result = res = 543
