For now. Sooner or later you're going to need that file.It drives my antvir crazy and i have removed it and SourceBoost works fine
#ifdef _BOOSTC
#define FOUND_COMPILER
#define lata_ lata
#define trisa_ trisa
#define porta_ porta
#define latb_ latb
#define trisb_ trisb
#define portb_ portb
#define intcon_ intcon
#define intcon2_ intcon2
#define osccon_ osccon
#define t0con_ t0con
#define t0con__ t0con
#define adcon1_ adcon1
#include <system.h>
#pragma CLOCK_FREQ 8000000
#pragma DATA _CONFIG1H, _INTIO2_OSC_1H
#pragma DATA _CONFIG2H, _WDT_OFF_2H
#pragma DATA _CONFIG3H, _MCLRE_ON_3H
#pragma DATA _CONFIG4L, _LVP_OFF_4L
#endif
// MCC18
#ifdef __18CXX
#define lata_ LATA
#define trisa_ TRISA
#define porta_ PORTA
#define latb_ LATB
#define trisb_ TRISB
#define portb_ PORTB
#define intcon_ INTCONbits
#define intcon2_ INTCON2bits
#define osccon_ OSCCONbits
#define t0con__ T0CONbits
#define t0con_ T0CON
#define adcon1_ ADCON1
#pragma config OSC = INTIO2, WDT = OFF, LVP = OFF
#include <p18f1320.h>
void interrupt(void);
#pragma code low_vector=0x18
void low_interrupt (void)
_asm GOTO interrupt _endasm
#pragma code
#pragma interruptlow interrupt
#endif
#ifndef FOUND_COMPILER
error: unknown compiler
#endif
hey guys this is a nice topic. I want to start using 16F pics again also and want to confirm you guys recommend BoostC right? I want to write in C mainly for portability.
I just dowloaded boostC. My pic of choice to test and play is a PIC16F627A and i wanted to know. With boostC can it be MPLAB friendly? Like can i compile from MPLAB? I havent tried it in a while lol.
Scratch that i just installed and it asked me lol
Can someone post a small blink led sample please. So i know how to setup any configs and such.
I tried sysclean it said it was ok But if you lost years of things you watch for them to.Maybe you should remove the anti virus.
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\SourceBoost\boostc.pic16.exe" test.c -O1 -W1 -t 16F627A
Thread would not exit normally.
Could not read language tool output from pipe. (5)
BUILD FAILED: Sat Feb 28 21:23:29 2009
Clean: Done.
Executing: "C:\Program Files\SourceBoost\boostc.pic16.exe" Atomsoft.c -O1 -W1 -t 16F627A
BoostC Optimizing C Compiler Version 6.91 (for PIC16 architecture)
SourceBoost Technologies - Home of BoostC Free PIC C Compiler and BoostBasic Free Pic Basic Compiler
Copyright(C) 2004-2008 Pavel Baranov
Copyright(C) 2004-2008 David Hobday
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
Atomsoft.c
success
Executing: "C:\Program Files\SourceBoost\boostlink.pic.exe" "C:\Development\PIC Projects - Boost C\Atomsoft.obj" -O1 -p "Atomsoft" -t 16F627A
BoostLink Optimizing Linker Version 6.91
Optimisation level:1
Building CASM file
Memory Usage Report
RAM available:224 bytes, used:0 bytes (0.0%), free:224 bytes (100.0%),
Heap size:176 bytes, Heap max single alloc:95 bytes
ROM available:1024 words, used:10 words (1.0%), free:1014 words (99.0%)
success
Loaded C:\Development\PIC Projects - Boost C\Atomsoft.COF.
BUILD SUCCEEDED: Sat Feb 28 22:47:33 2009
Jason! Leave out the #include <PIC16F627A.h>. The compiler will do that for you.Code:#include <system.h> #include <PIC16F627A.h> #pragma CLOCK_FREQ 4000000 #pragma DATA _CONFIG, _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF void main() { trisa = 0x00; set_bit( porta, 0 ); while(1); }
you need that for a Quick buildJason! Leave out the #include <PIC16F627A.h>
how will it know what chip if you don't tell it
