87handmedown
Hi all. I stumbled across this forum after spending many hours searching for help on my problem. I searched for several hours on here and didn't find what I was looking for (or maybe I did and I just didn't understand it) so I decided to formally join this site and talk to you guys. I do well with analog systems, but this new digital age is leaving me in the dust. I feel confident in my abilities to tackle this problem, I just don't know where to start right now. Enough background already, here's the situation.
I've got a vehicle/kart that me and some friends are building that is powered by a 4cyl motorcycle engine. It has manual brakes, and is fuel injected. We would like to have a traction control system on the car that reduces engine power in order to eliminate the large amounts of wheel spin that occurs under heavy acceleration, and reduce the over steer that happens when we get into the throttle too soon coming out of a corner.
My idea was to place three or four (two on the front, and then one or two on the rear depend on whether I used the drive gear, or both rear wheels) Hall sensors to create voltage signals. Once these voltage signals differ by a determined amount ( amount of slippage) I want a small system to activate one (or possibly two, depending on how much power we need to cut) relays that interrupt the signal to the injectors to stop one or two injectors from delivering fuel until traction is restored.
The problems are: I'm going to need to average the two front signals so the TCS doesn't activate when the car is turning, I have no idea how to do this. I don't know how to even begin to build the computer/system that is needed to determine slippage and activate my relays.
Like I said before, I have done a LOT of searching, probably close to 18 hours worth trying to figure this out. I did find one website where someone did something extremely similar. Here is the link
Project - Homemade Traction control
and I tried e-mailing him to get more details but his address is no longer valid.
I'm really frustrated right now because I really don't know much about these types of electronics and my searching hasn't netted me many results. I hope that this isn't an impossibly difficult project, as the above website makes it seem close to what I had invisioned, I just don't know how to get to that point. If any of you could offer me any advice at all, it would be greatly appreciated.
Thank you
Thank you
