btfsc instruction
gregmcc
I seem to having endless problems with this simple instruction.
If I have the following code:
movlw b'00000000'
btfsc W, 0
goto Intrusion
goto Main
According to the datasheet - btfsc: If bit is set then skip next instruction. On the above bit zero is clear so it should execute the next instruction. Why's it that my mode keeps jumping to Main :(
movlw b'00000000'
btfsc W, 0
goto Intrusion
goto Main
You need to try reading the datasheet! - BTFSC can't be used on the W register, only on file registers - the only reason it assembles OK is that W is in the include file as a destination.
Thanks - that might explain why I was having trouble :)
I've done a search through the 16F62X datasheet and under the BTFSC instruction it doesn't mention anything about not using the W register. Unless of course I'm not reading it correctly, which by this stage anything is possible. <grin>
It's in a section for action only on file registers - W is defined in the include file as either 0 or 1 (can't remember which as you never need to know). So your line actually read:
btfsc 1, x
or
btfsc 0, x
To test bit 0 of W you can do the following,
     andlw  b'00000001'
     btfss  STATUS,Z
     goto   BitWasOne
To test a different or multiple bits just change the 0's to 1's.
The above does of course corrupt W.
 andlw  b'00000001'
     btfss  STATUS,Z
     goto   BitWasOne
Z: Zero bit
1 = The result of an arithmetic or logic operation is zero
0 = The result of an arithmetic or logic operation is not zero
gregmcc said:
Thanks - I'll paste that right into my code :)
Or just copy W to a file register, and check that - this doesn't alter the W register.
Using ANDLW is really a 'non-PIC' method though, most processors don't have bit-wise instructions, and logical operations on the entire byte are the only way to test, or modify, individual bits. PIC's are designed for low level operations, and thus have bit-wise operators - you may as well use them?.
movlw b'00000000'
movwf Temp
btfsc Temp, 0
goto Intrusion
goto Main
     andlw  b'00000001'
     btfss  STATUS,Z
     goto   BitWasOne
Above code is right???
plz guide me that
if W = 0000 0001 AND Litrel = 0000 0001 then Z = ???
plz guide me that
0000 0001 AND 0000 0001 = 0000 0001
0000 0001 is not equal to 0
Therefore Zero flag = Not True = 0
