danielsmusic
I moved the crystal a lot closer to the PIC and removed the wires connecting it. Although this did not change anything. The PIC still will not work if I don't put some sort of load on any of the pins and hold it high. I still cannot put capacitors in the circuit or it stops working. I checked for any short circuits with my multimeter and it is ok. I changed the LEDs and resistors to lower the current drawn from them. Nothing is helping
I do have normal insulated wire, but I don't use it on breadboards. It is messy, tinned wire does the job perfectly. The circuit works as it is, but without capacitors and I need to hold a pin high.
