Boost power supply problem
when i ran my circuit last it was rapidly gaining tempurature. It got very hot in less than a minute and it was using anbout 0.9A. Why could this be then?
You should use a PNP/NPN transistor pair to drive a MOSFET. When you use a mosfet it will have much less on resistance than a NPN transistor, and it will then have much less heat dissipation.
0.9A from 5V is only 4.5W. The fan probably used most of it.
And as I said you will need over an amp of input current to get like 200mA of 12v on the output, and as far as I know, most 12volt fans use about 2.4 watts, so you would expect maybe a power draw of around 5 watts at 5volts.
-Ben
Do you have the new inductor already? If the inductor is too small it will destroy the transistor because after a short time the transistor will be forced out of saturation and yet still have full current through it so that will cause a very large amount of heat in the transistor. You really need an inductor with a higher value for this to work. We calculated 310uH as the min, but that's the minimum value so you could go higher like 400uH. I wouldnt argue with 500uH either as Mr RB pointed out earlier.
