Bluetooth Register Draw
You could but you should check that the software you're using will pair with any device and is able to send the correct command. If it's standard software then it probable won't work. You'll also need two power supplies - 5V & 12V
mike.
Really depends on your application. For example, the bluetooth device might have to act as a printer in order to receive the command for opening of the drawer.
