Baud Rate assembly coding
Spadez
Hi.
I have my code working using this code off microchip:
        movlw .25              ;
[COLOR="red"]	banksel SPBRG[/COLOR]
        movwf SPBRG
        movlw b'00100100'       ; brgh = high (2)
[COLOR="red"]	banksel TXSTA
[/COLOR]        movwf TXSTA             ; enable Async Transmission, set brgh
        bcf STATUS,RP0          ; RAM PAGE 0
        movlw b'10010000'       ; enable Async Reception
[COLOR="red"]	banksel RCSTA[/COLOR]
        movwf RCSTA
; PROVIDE A SETTLING TIME FOR START UP
[COLOR="red"]        clrf dataL
settle  decfsz dataL,F
        goto settle
	banksel RCREG
        movf RCREG,W
        movf RCREG,W
        movf RCREG,W            ; flush receive buffer[/COLOR]
	return
However, I need to use this supplied code:
movlw b'00100100'
movwf   TXSTA               ; setup 8 bit serial transmission, high baud rate
movlw   .25
movwf     SPBRG         ; set baudrate 9,600
bcf  STATUS,RP0 ; select Bank 0
movlw     b'10010000'
movwf       RCSTA           ; enable serial port, and continuous reception
return
Are these codes comparible to the point where I could simply drop the second in as a replacement for the first? For example, ive highlighed the lines in the first code which dont appear in the second code in red. Also, is the settling time needed?
Any input on this would be very helpful, thank you.
I don't think that the settling time is needed for the USART, but it's a good idea to have a settling time at the start of a program, to make sure the power has had time to stabilise.
Once you have turned on the USART, you should either regularly poll the receive flag or have a receive interrupt. It isn't a good idea to let the receive buffer fill up, so the delay after turning on the USART isn't a good idea. It's better to disable the USART then enable it, which will an overflow.
The
banksel RCSTA
is a macro that changes the status RP0 and RP1 so that RCSTA can be accessed.
I don't know which processor you are using, and different processors have the RCSTA, TXSTA, SPBRG etc in different banks, so you will have to look up to see where they are, which will tell you whether you need the change banks in the code.
