battery experts....AAAA equivalent li ion??
strokedmaro
I'm looking for a battery equivalent (in size anyway) to a "AAAA" battery in lithium ion rechargeable. Does anyone know a model number or a website that would sell such a thing? I know I could get 6 AAAA's out of a rechargeable 9 volt but the capacity on NiCd is not good enough. I'm looking at lithium ion 9 volts as a last ditch effort.
What I really need is a battery in the 9-10mm diameter department anywhere from 50-60mm long with at least a 180mAh capacity. Ideally Id like a 3.6 vdc single battery but 2 or 3 shorter batteries that can be stacked (series voltage not a problem) to meet the height (and diameter) requirements would also suffice. ANY HELP APPRECIATED!!! :D
EDIT:: flexible cells are also acceptable if they can be rolled safely into the desired diameter (9-10mm)
A 9V Ni-MH battery has a capacity of only 175mAh to 250mAh at a fairly low current. Each cell's voltage is 1.2V to 1.25V for most of a discharge.
A lithium -ion battery cell is 4.2V when fully charged and its voltage gradually drops to 3.0V when its load should be disconnected. Its average voltage is 3.6V.
