Ayne said:
I need 1A current on both side(+,- V).
currents will be simultaniously...
I have 35-35Volts center tape transformer rated current on it is 2A.
You really need a 28V-0-28V transformer, either that you you could try building a 39V pre regulator using a transistor and zenner but this isn't an ideal solution.
Also consider using an LM317 and LM337 in place of the LM7809 and LM7909, the LM7805 and LM7905 can then be connected internally to the output.
Also please note that the voltages on the transformer secondary and from the output from the supply are hazardous and are above the legal in the UK and Europeean limits for allowing physical contact with. The IEEE regulations state that in dry contitions user contact shall be avoided with voltages greater than 25VAC and 60VDC. On your poposed project the secondary side of your transformer gives 70VAC, 98VDC on the output capacitors and 70VDC on the output.
I would lower the maximum output to +-30VDC and use a 24V-0-24V 2A transformer, there will still be hazardous voltages in the case but at least the output will be relativity safe. Be aware that 60VDC is the maximum and is only considered safe in dry conditions, it is high enough to give you a fair shock if you have wet skin.
Will TL072 Work???
I need out put impedance 100
hm:
As audioguru says, find a faster op-amp, pay particular attention to the slew rate as well as the unity gain bandwidth.
Alternatively, you can get ICs function generators to make square, triangle and sinewaves. If you can find and old ICL8038 then great it will work up to 200kHz but it's no longer made, however there is the new MAX038 which goes up to 20MHz but it's expensive. Forget about using it upto said fequency and expect the PIC to count it, but there's always the option of adding a divide by 10 counter. Personally I'd prefer the challenge of desigining my own.
Can u help me for protecting output from short circuit???
Like I said before, the regulator ICs will protect against that, but for extra protection you should add a 2A polyswitch in series with both outputs from the transformer secondary.
Yes i want to like to adjust the duty and frequency seperately, Guide me more.
Plz help me with tutorials or any web link
The best way would be an oscillator with a 50% duty cycle using the TS555 and then connect the timing capacitor to one input of a comparator and vary the reference voltage on the other pin. You'll now have one output with a variable duty cycle and another with a fixed duty cycle.
This is quite an easy circuit to make but what sort of output do you need? Just 5V or something more exotic? It could be variable but 5V is normally adequate.
I only know the MikroBasic and i have made some little programs like LED flashing etc.
That's more than I know but it doesn't sound too difficult.
In general I think you need to consider what you need rather than what you want. How many circuits have you built or even wanted to build that require a bipolar 5V, 9V and 35V power supply?
Probably not that many.
A positive and negitive 15V supply is probably more than good enough for most applications. Perhapps you could make do with a positive and negitive 2 to 15V supply or a bipolar variable power supply like the one I've built.
https://www.electro-tech-online.com/threads/variable-bipolar-power-supply.24291/
I agree a separate 5V output or even bipolar output is always handy though for powering TTL or CMOS circuits but I wouldn't normally need anything more.
As for a signal generator, do you really need a 1MHz sinewave? Normally 20kHz is more than enough, 100kHz normally being the max for testing audio amplifiers with.
Google be your friend, there is a wealth of information out there. If you can't find what you want then try narrowing your search criteria, broadening it or trying various keywords and synonyms.
