hello all,
i'd like to replace my stock fan switch in my car with a PWM circuit + MOSFET setup to drive the blower motor. I've been doing some research (got plenty of links and datasheets to mull over) into it and I've got a PWM circuit that should work well, but I have a couple questions.
1) MOSFET driver IC.
What is exact reasoning behind using this part? From what I've read it might have something to do with the gate capacitance (to allow faster switching)? And also to bump up the voltage from the PWM output to satisfy the gate threshold voltage requirements? So I need to match the output of the driver IC to the Vgs of the MOSFET, correct?
Since this is a blower fan, I only need one direction, so I think a single channel driver IC is the correct thing to use. Can anyone suggest a specific chip/model?
2) Current Requirements
The current circuit the fan is on has a 40A fuse, so I'm assuming that is the minimum current I should aim for. In regards to this, how should I design my PCB? What width should I make the traces connecting to the MOSFET? Is it even safe to mount it to a PCB, or would I need like 2" wide traces? (Sorry if this sounds newb-o-rific). I am aiming to switch at ~20kHz, as this seems to be the correct frequency to avoid noise from the motor (from what I've read).
thanks for lookin and i appreciate any help on my project
dex
dex
