Ascii to 7 segment
Mosaic
I searched the forum and couldn't quite find a utility i needed...so I built this 16F code.
It allows easy character conversion on the fly from a look up table.
Input is ASCII in wreg...returns a com cathode 7 segment bit pattern.
Special handling for spaces, underscores, dashes & @ sign.
Handles 0-9 Numeric and alphabet @-z (lower case)
Note that some letters k,m,v,w,x, don't display well.
Hope it's useful to others.
ASCIIto7seg;
	movwf  Tmp
	sublw 0x2d
	skpnz
	goto Dash
	movf Tmp,w
	sublw 0x20
	skpnz
	goto Spc
	movf Tmp,w
	sublw 0x5f
	skpnz
	goto Underscore
	movf Tmp,w
	btfsc Tmp,6 ; skip next if numerals, else
	goto alphabet
	andlw b'00001111' ; as numerals 30h - 39h ascii
	addwf PCL,f ; offset prog counter to lookup which # to be displayed
	retlw 0x3f ; code for 0, bit 7 is the dot. Common cathode. Invert values then clr bit 7 (dot) for common anode.
	retlw 0x06; 1
	retlw 0x5b; 2
	retlw 0x4f ;3
	retlw 0x66 ;4
	retlw 0x6d ;5
	retlw 0x7d ;6
	retlw 0x07 ;7
	retlw 0x7f ;8
	retlw 0x67 ;9
alphabet;
	andlw b'00011111'; as alphabet  >= 60h ascii
	addwf PCL,f
	retlw 0x80; return a decimal rather than @ sign.
	retlw 0x77 ;A
	retlw 0x7c ;b
	retlw 0x58 ;c
	retlw 0x5e ;d
	retlw 0x79 ;E
	retlw 0x71 ;F
	retlw 0x3D ;G
	retlw 0x74 ;h
	retlw 0x10 ;i
	retlw  0x0e;j
	retlw  0x70;k - avoid
	retlw  0x38; L
	retlw  0x37;m - avoid
	retlw 0x54 ;n
	retlw 0x5c;o
	retlw 0x73 ;P
	retlw 0x67;q =>like 9
	retlw 0x50 ;r
	retlw 0x6d;S =>like 5
	retlw 0x78;t
	retlw 0x3e ;U
	retlw 0x62;v => like a superscript u.
	retlw  0x7e; w - avoid
	retlw 0x76;x => avoid, like H
	retlw  0x6e; y
	retlw 0x5b; z => like 2
Underscore;
	retlw 0x08; underscore
Dash;
	retlw .64; -
Spc;
	retlw 0x00;
Very nice, this is one of those things that lookup tables are great for.
