Arrays Oshon Pic Basic
SwingeyP
Hi can anyone help me with this please?
I want to store a string something like this
DIM bargraph(10) as Byte
bargraph(6) = s_p, #sr, " ", 0, 1, 2, 3, 4, 5, 6, " "
or perhaps three is a better way?
I have this code:
bargraph0:
Lcdcmdout LcdLine2Home
Lcdout s_p, " ", "0 "
WaitMs 1
Goto home
bargraph1:
Lcdout s_p, #sr, " ", 0, " "
WaitMs 1
Goto home
bargraph2:
Lcdout s_p, #sr, " ", 0, 1, " "
etc.....
It seems to me that it would be great to do something like this here instead
bargraph:
Lcdout bargraph(var)
Goto home
that way I could just call 1 line which would read the array element associated with var.
Is this possible?
Regards - Paul
hi Paul,
Have you considered using the LOOKUP statement for Strings.??
eg;
FOR DIGIT = 0 TO 9
bargraph = LOOKUP(s_p#sr 0123456), DIGIT
lcdout bargraph
NEXT DIGIT
Hello again Eric.
I haven't used lookups before. I just had a quick read of the help file in oshon.
So I could do someting like this then.
mask = LookUp(" ", "0 ", #sr, " ", 0, " ", #sr, " ", 0, 1, " "), var
lcdcmdout s_p, mask
etc...
Regards - Paul
Hmmm just realised i'd have to be careful with quotes and commas. Would each parameter require single quotes?
I can't get the construct of the strings right. Can anyone help please?
Here's what it is at present.
bargraph0:
WaitMs 1
Goto freq
bargraph1:
WaitMs 1
Goto freq
bargraph2:
WaitMs 1
Goto freq
bargraph3:
Lcdout s_p, #sr, " ", 0, 1, 2, " "
WaitMs 1
Goto freq
bargraph4:
Lcdout s_p, #sr, " ", 0, 1, 2, 3, " "
WaitMs 1
Goto freq
bargraph5:
Lcdout s_p, #sr, " ", 0, 1, 2, 3, 4, " "
WaitMs 100
Goto freq
bargraph6:
Lcdout s_p, #sr, " ", 0, 1, 2, 3, 4, 5, " "
WaitMs 1
Goto freq
bargraph7:
Lcdout s_p, #sr, " ", 0, 1, 2, 3, 4, 5, 6, " "
WaitMs 1
Goto freq
bargraph8:
Lcdout s_p, #sr, " ", 0, 1, 2, 3, 4, 5, 6, 7, " "
WaitMs 1
Goto freq
So how do I do
lcdcmdout s_p, mask
Regards - Paul
For ASCII characters in the LOOKUP string use double quotes ONLY at each end of the string.
For mixed hex, ascii ("123",22h,31h,"the quick brown fox")
Regards - Paul
You MUST use a FOR...NEXT loop to select each table character in turn.
Do you need an example.???
Thanks Eric.
Just a quickie, I need to start using a procedure buy OSHON gives me error 282. Support for functions and procedures is not enabled. How do I enable them?
Thanks Eric.
hi Paul,
Its an option you have to purchase from Oshonsoft, IIRC it part of the MATH32 support.
hi Paul,
Look at this demo option.
'for demo the strings are 10 characters long
'set the CONST to suit the 1st EEProm address of the string
'EEPROM addresses start a 00
Const name = 0
Const deci = 11
Const oshon = 22
Const pic = 33
Lcdinit
Gosub wr2eep  'write the strings to EEPROM, once ONLY
main:
Lcdcmdout LcdLine1Home
str = name
Gosub str2lcd
str = deci
Gosub str2lcd
Lcdcmdout LcdLine3Home
str = oshon
Gosub str2lcd
Lcdcmdout LcdLine4Home
str = pic
Gosub str2lcd
Lcdcmdout LcdClear
Goto main
End
'read a string from EEPROM and displays it
str2lcd:
For addr = str To 99
Read addr, chr
If chr = "," Then Return
Lcdout chr
Next addr
Return
'this section stores the strings in EEprom, only required once.
wr2eep:
For pntr = 0 To 99  'this 99 will fill the EEprom after the text with ","
chr = LookUp("Eric Gibbs,0123456789,Oshonsoft ,PIC 16F877A,"), pntr
Write addr, chr  'write to EEprom
addr = addr + 1
Next pntr
Return
oh right. time to upgrade then. I'll send a mail and enquire about upgrade.
Thanks Eric.
Regards - Paul
