littletransistor
Hi there. I've been studying about these theories about transistors in my university, and learning how to apply these in an example osciliator circuit.
However, I'm not sure where do the current starts flowing first - from the negative side of the battery or from the positive side instead. I can do the simple transistor calculations (like base voltage needed to saturate the transistor) but couldn't grasp the idea of how the capacitor suddenly got its polarities changed, or it's charge/discharge when it's connected.
I couldn't find the value for the minimum voltage in the NPN's base to saturate it, and then turn on the PNP - everytime I do the calculation I get a value of 1000 volts and above. Is there a way to derive current/voltage needed for the circuit? And also, how can I calculate how much is voltage stored into the capacitor when it's charging? And how about the flashing rate?
The only thing I know is calculating and the theory of saturation/cutoff. But applying these onto the real circuit is very difficult. And I couldn't get to know the flow of the current at all. Please enlighten me.
