We could probably help out some more if you gave more detail. As was said, TTL is transistor-transistor logic. Typically, you have a low value if the voltage is less than 0.4V, and a high value if the voltage is greater than 2.4V. Anywhere in between is indeterminate.
What chip are you using? It's spec sheet will probably have better values for you.
