Rohit Chatterjee
How do antennas operate????Can anyone explain me the fundamentals of antenna operations....
Note: This feature currently requires accessing the site using the built-in Safari browser.
Have you tried entering Antenna Fundamentals or Antenna Basics into your web browser? I did, and came up with many, many links on the topic. Try it for yourself!How do antennas operate????Can anyone explain me the fundamentals of antenna operations....
It is a half-wavelength for a horizontal dipole, and a quarter wave length for the end fed vertical. How it works is described by the solutions of the the partial differential wave equation. Hueristically waves move along conductors until they reach an impedance discontinuity. At the discontinuity a portion of the wave passes through the discontinuity and a portion is reflected back to the source. What you try to do is "tune" the antenna by changing its geometry so that at a particular frequency or a narrow band of frequencies most of the energy passes through the impedance discontinuity and only a small fraction is refelected back. This condition is referred to as resonance. A transmit antenna that is resonant on a particular frequency is also a good receive antenna for the same frequency.basically, an antenna/aerial is a none shielded material that helps in radiation of radio waves. Transmitting aerial is for transmission, receiving aerial is for receiving, but it is possible to use one antenna for both function. theoretically, a wave could be transmitted effectively if the length of the transmitting antenna is roughly equal to wavelength of the wave to be transmitted. google the rest.
You mean I didn't succeed in explaining it to your satisfaction. Well sorry, but what exactly is the disconnect here? What is missing?Well this isnt my homework at all....its one of the papers in my course....i have tried out Jordan Balmain and Balanis....but they werent satisfactory....the concepts such as far field E and H fields,and directivity and all are explained in details....but the fundamentals arent explained properly....at least thats what they seemed to me.....i was just hoping if anyone could explain the basics of antenna radiation.....thnx to all.....
It depends on the frequency range, direction of polarization, and other things. It's an interesting subject, but not one that can be taught in a single sitting.How do antennas operate????Can anyone explain me the fundamentals of antenna operations....
It is a good explanation, but I'd be surprised if the OP can swallow it any easier than the material he has already perused.
Actually he wants some practical view of some one on antennas.
1. In the solution to the partial differential equation, the quarter wavelength and half-wave length boundry conditions enhance the ability of the antenna to radiate at that frequency(wavelength). At the same time other frequencies are not radiated so efficiently.I think i should have explained the problem a bit more clearly....i wanted to understand the basics....like why does an accelerating electron radiate...(i know a bit now thanks to the link provided by Mr.RadioRon...)....
A couple of last things i would like to know....
1.What is it about the length of the antenna???Why does it have to be a quarter or half wavelength????
2.Why is it that only the antenna radiates significant amount of energy????Doesnt the TL which connects the source to the antenna radiate as well???Why cant we replace the antenna with just an ordinary piece of Cu wire????
A special thanks to Mr.Papabravo....your explanation about the impedance matching part was quite helpful....its just that i should presented my problem in a better manner....thnx for your efforts.....
Seems to me the behavioral description has a lot going for it. Without getting into the mathematics you can understand from observing a water wave in a tank with a porous membrane at one end. Send a wave down the tank, when it gets to the membrane part of the wave gets through and part of it is reflected back. Waves are waves after all.
I don't agree with that statement at all, but why should I argue with you. We don't need the simplified explanations. We've jumped the shark.Maybe, but electromagnetic fields are hardly that easy to model and the problem is they behave differently for no reason anybody can understand. If I recall correctly, Einstein went to his grave unsuccessfully tring to come up with a theory that could unify the behavior of fields.
In physics, a unified field theory is a type of field theory that allows all of the fundamental forces between elementary particles to be written in terms of a single field. There is no accepted unified field theory yet, and this remains an open line of research. The term was coined by Albert Einstein who attempted to unify the general theory of relativity with electromagnetism.
