Amplifying 1.5v to 7v
jeyes56
hi, im doing some project, and i forgot how to deal with transistors..
i want to amplify my 1.5v input to around 7v output.
how to do that with some sort of transistors and resistor only? (or with capacitor).
can please someone post a circuit diagram?
would that be ac or dc?
What is the supply voltage?
What transistors do you have?
What is the input signal source (impedance)?
What load does the amplifier have to drive?
Can you tolerate a fixed offset voltage between input and output?
supply is 9v.
I'm not familiar with transistors type, or serial. (what can you suggest?)
the load will drive a 6v relay.
"Can you tolerate a fixed offset voltage between input and output?"
i think i can't understand this statement.
The simplest method: opamp an two resistors.
You could use an LM358 in a noninverting configuration and a 10k and a 36k resistor.
Ok, I see now that what you need is a NPN transitor used as a relay driver (not an "amplifier").
You didn't say what the 1.5V signal comes from? ( I need to know this to see how much current the source can supply to drive the base of the transistor)?
I also need to know the resistance of the 6V relay coil? (Measure it with an Ohmmeter, or look up the datasheet)
