Amplifier power and volume.
Pepsiiuk
Hey,
Sorry to bring up the topic of the dreaded decibel again but I’m a bit stuck on the subject regarding amplifier power and volume (SPL).
I have been told that you need 10 times more power to double the volume of a speaker but I don’t quite understand why. I know ears work in a log scale but I can’t seem to link everything together.
Could anyone please help me out? A quick example and explanation would be great.
Thanks.
A(in dB) = 10 log A
where A is the gain
does this make any sense?
It does but thats part of the problem. Ive alsways understood that a 3dB increase is double the original. But going back to needing 10 times more power, 10 log (10/1) = 10 not 3.
well you know the answer!
log (10) = 1
log(100) = 2
so the gain 10, 100 etc are getting multiplied by 10 each time while the ear detects the gain in dB which is 1, 2 etc...
i.e for the sound to be twice as loud the actual gain must be increased 10 folds; 10 times the initial power is required :)
Hey,
Thanks.
Here are the assumptions that need to be discussed:
If Power1 into a given speaker produces a SoundPressureLevel1, does doubling the power produce an SPL2 which is double? (I say yes)
Does SPL2 sound twice as loud as SPL1? (I say yes, but I'm less certain)
Doubling power to the speaker is a 3 db increase,
e.g. 10*log(8/4)=10*0.301≈3.
Does this sound twice as loud?
The perception of sound levels is quite subjective. Most studies indicate that a 3dB change is barely perceptible and a 10dB change causes a doubling of the perceived level.
That is why a 3dB variance in a speaker response with frequency, although appearing to be significant, is not that noticeable to the average listener.
MikeMI: That’s what I assumed but apparently it’s not.
This would make sense with the equation i just found.
SPL = 10log(Power) + sensitivity
Say we have a speaker with 90dB/W/m at 10W
SPL = 10log(10) + 90
SPL = 10 + 90
SPL = 100dB
but with the same speaker at 100W
SPL = 10log(100) + 90
SPL = 20 + 90
SPL = 110dB
which as you said 10dB increase is perceived to be twice as loud.
If this is correct I know where I was going wrong. I assumed that double the perceived volume is a 3dB increase where it is actually a 10dB increase.
Does that mean that a speaker with a sensitivity of 93dB is only slightly loud than one with a sensitivity of 90dB?
Thanks for your help
Actually double the power 3db increase is barely louder to a human, 1DB is considered the lowest amount you can increase acoustical power before a human can detect it. So 3 is only slightly above what someone will notice, Humans have logarithmic hearing. Which is why we can hear such infinitesimally small sounds. In the case of a 100 watt speaker, you would have to increase the power to 125 watts JUST to get a human being to notice that you increased the volume at all. Exponential diminishing returns on power vs perceived volume.
