I'm quite new to Electronics, and have been working on understanding an AM radio circuit. I think I've gotten most of it, but I'm stuck at a few points.
The schematic can be seen at http://support.radioshack.com/support_games/doc60/60245.htm, or, for a better picture, at https://www.electro-tech-online.com/custompdfs/2003/11/64800.pdf.
Here are my questions:
A) Block (1) - I recognize the tuned circuit, but its not in any configuration that I'm familiar with. Normally, I've seen the signal come in, and a tuned circuit bypass to ground, and then signal out. Here, I don't see any signal in (where does the antenna connect to?) or signal out - only to ground. How is this working?
B) Why is an inductor used to couple to Q1?
C) There are several capacitors which bypass to ground along the way - from right to left, a 0.1uF, a 0.01uF, another 0.01uF, and a 0.05uF. Are these all used to detect the AM - that is, to let the HF drop to ground while the audio carries through? Why do you need so many?
D) Block (4) - How can you couple with only a 0.022uF capacitor - won't this block all but the lowest frequencies?
I'd like to thank anyone who can help me, by answering any of these questions!
