Aiwa Z-R700 music hifi has dim lighting and none of the systems work when powered up
radio man
I was given a 1990s Aiwa Z-R700 music system to have a look at because the tape deck was not working, cd player and tuner worked ok. I replaced the belts on the tape deck as they were all broken, Now the cd player, tuner and the tape deck do not work and the front lighting is all dim when the unit is switched on. I have checked connections and ribbon cables and there are no burnt or swollen capacitors on the main board. Maybe there are capacitors with low esr, bad diodes etc, I just don't know. Has anyone ever repaired one of these systems, I would be really grateful if someone could help please, give me some clues maybe, as I have never worked on one of these systems before. I know it is from the nineties but it is a nice unit. Thanks, Radio Man
If the power supply is unstable or provides incorrect voltages, it can cause malfunctions across different components. Use a multimeter to check the output voltages against the service manual (if available).
Thank you for replying. I haven't got a service manual, I have searched for one without any success yet, I will have another look for one.
As it worked before you replaced the belts, it's pretty likely that you've disturbed something, or connected something to the wrong place, it's unlikely to be an actual 'fault'.
A simple google finds the service manual:
